When I have greending noise(IBM drive sings) - הלהיט.
טוב, הנה משהו שכתבתי. החלטתי להשקיע את הכשרון הפואטי שלי בזמן שמשהו ירד במשהו קצב מבדר(זה מבוסס על When I am 64 של החיפושיות):
When I get wobbled
crashing my heads
a few minutes from now...
Will you still be sending me to a repair?
To the shop or the importer.
If you install me infront of fan
don't you close the case!
Will you repair me? will you replace me?
When I have greending noise...
WD had also crashed....
and if you use me less
I will stay with you!
I can't be handy
banding my heads
and all your data is lost.
I can be a usefull paper holder
Sunday morning pray in the church.
8 hours of working, without any files.
Who could ask for more?
Will you repair me will you replace me?
when I have greending noise.
Every summer I should be double RAMed
If I worked too much.
The heads: We shall scratch and crash...
Bad sectors on my plates
I will choke and crash.
Back-up your data,
Don't drop a line.
I am stating point of view...
My noise is indcating what I mean to say.
Yours sincerely,
waste me away.
Decribe all my troubles
when filling the from
of the RMA!
כל הזכויות למילים החדשות כמובן שמורות אך ורק לי.
המממממ ......... אתה צריך או דרמל או חברה . אתה תבחר מה יותר מתאים לך . :o
אין דברים אחרים לעשות בחיים?
