wireless router
Hi guys,
Sorry about the english post, but I'm abroad now and there is no hebrew support here.
When a adsl router is described to have (for example) 4 lan ports and 1 wan port, does it mean it I can connect to it only 1
wireless computer, or having a wireless port means the router can support many wireless computers?
Thanks
HI,
I will answer in english in case you cant also read hebrew.. (dont think so but never mind now)
Anyway...
A WAN in thr wireless router means the entry on the DATA which means in this case the ADSL Modem.
4 lan ports means that you can connect up to 4 computers with Cables to the router.
A wireless router can connect up to 256 wireless users (!!!) and sometimes even more (So dont worry about the number of wireless connections)  ;D
    OK, thanks
    I have another question
    Can you reccommend me of a good ADSL modem + wireless router?
    (Preferable in the same box, meaning I don't want to connect a regular ADSL modem
   to some wireless switch).
   BTW, I can read Hebrew here, just can't write it
