Help with a "tiny" upgrade
Hello, first of all my hebrew fonts are screwed and I dont have power to fix it so sorry for the english... anyway Its time after allmost 2 years to upgrade my pc  ;D I wanna run FarCry/Doom3/HalfLife2 after all dont I ?  :cool2:
Anyway the parts im gonna upgrade is this:
Leadtek GF4 TI4400
Athlon XP 2000+ (0.18micron...fucking toaster oven)
GA-7VRXP 2.0
so I need a new graphic card, motherboard and processor.
I have 2000nins to spend (after working this summer hehehe) I thought mabye I will get exoneration (zhikoi) for the old parts so it will sum up to about..uhh.. dunno +600-900nins ? could be cool if you can tell me how much I can get from this parts.
Now I check the specifications (mafretim) in the website and I saw:
AMD Athlon64 3200+ 64bit 2000MHz, 1mb 1600Mhz HTB - OEM
VIA K8T800 - Albatron K8X800 Pro II - 7.1 ViaEnvy audio
Radeon 9800 Pro (380/680) 128MB DDR 256bit 8-Pipes - Sapphire OEM
now fine with me with the Athlon64 3200+ but I saw in the forumstheres newcastle and sledgehammer? whats better?
same with the VIA K8T800 the forums says theres a new one? pro? im not gonna OC so fast if ever becuase I will need this pc for a year then I will join the army so I need it for this year... the year of the VERY heavy games and I want it to work without leaping and low fps im sick of it  :'(
oh and of course the Radeon 9800 Pro im not sure if its enough... should I Invest in the costly Radeon X800 ? if there is need my parents will add some money (hehehe some... i guess it will be 2000nins more) but well I see in the forums that the MSI GF8600 is the best and i can use RivaTuner to make it GT like anyway I ask for you help if you can   :)
Thanks  :xyxthumbs:
המפרטים המומלצים באתר הם די ישנים..
בתקציב של 2000 שקל אתה לא יכול להכניס את מה שרשמת רק ה9800PRO עולה 1300 שקל +
you might need new ram too
how much ram do you have? is it even ddr?
you need at least ddr 400/pc3200 for athlon 64
you cant have Albatron K8X800 Pro II/Athlon64 3200+/Radeon 9800 Pro for only 2000nis
it costs about 3400nis
Well like I said my parents would probably help with 2000nins more...if not I guess I will have to work more ;D
so I will have around 4000nins that enough no?
if you will have 4000nis , buy this parts :
מעבדי ?AMD? Price Units Total
Athlon 64 3200+ (S-754) 1280 1 1280
לוחות אם למעבדי ?AMD? EPOX Price Units Total
8HDA5J S-754 sata, gbl 570 1 570
כרטיסי מסך? MSI Price Units Total
GF 6800 128MB,TV,DVI 1950 1 1950
Total price 3800 ¤
its alot better , and the video card got an option for opening to 6800GT\ultra...(mod)
הלוח הזה לא משהו
עדיף את הלוח של nvidia
nforce 3 250GB
של epox.
במידה ולא מתוכנן OC אין הבדל בביצועים בין הלוחות. פותח התר'ד ציין שהוא אינו מתכנן OC, לכן ה-HDA5J נראה כאפשרות הטובה ביותר עבורו.
Hello and thanks for the offers, may i ask whats (S-754) in the athlon? also i was planning to get the MSI one just because of the gt/ultra ability
now about the motherboard i said im not planning but mabye in the future i will so whats the diff really between those 2 motherboards?
btw about the ram - i have 1024gb of ram ddr 333mhz
so i need new memory or some thing for the athlon 64?
gosh i feel like a n00b.. i was so into the hardware stuff 2 years ago but dunno just stopped with it :-\
thanks again!
