CAT 4.8 שוחרר :D
http://www.ati.com/support/drivers/winxp/radeonwdm-xp.html?type=xp&prodType=graphic∏=productsXPdriver&submit.x=6&submit.y=2
אל תשכחו לדווח בתוצאות בנצ'ים :D
תיקונים ושטויות אחרות:
3D Mark03: Display corruption is no longer noticed when running the Trolls Lair test 3 under Windows XP
Beyond Divinity:Playing the game with FSAA set to 2x no longer results in display corruption when scrolling the display by moving the mouse to the left of the display
High Heat Baseball 2003: The display no longer loses sync when exiting or changing player characters in the game High Heat Baseball 2003 under Windows XP with an ATI RADEON X800 series installed
Madden NFL 2003: The game no longer fails to respond under Windows XP when an ATI RADEON 9800 XT is installed and attempting to set the Truform slider to Application Preference
Need for Speed Underground:Playing the game under Windows XP with an ATI RADEON 9000/9200 installed no longer results in the road ahead not being lit up by the car's headlights
Splinter Cell Pandora Tomorrowisplay corruption is no longer noticed when launching a multiplayer game under Windows XP with an ATI RADEON 9200 installed
Thief 3:Inconsistent lighting and shadow flicker is no longer noticed when playing the game under Windows XP
Unreal Tournament 2004: Playing the game under Windows XP with an ATI RADEON X600 series installed no longer results in game corruption being displayed when setting Anti-Aliasing to 4x and having the display properties set to 1600x1200 32bpp
Resolved Game Issues
This section provides information on game issues that have been resolved in the latest release of CATALYST. These include the following:
City of Heroes: Specular lighting issues and incorrect textures is noticed when playing the game under Windows XP. Further information on this issue can be found at: www.ati.com/support/infobase/4561.html
F1 Challenge: A performance decrease is noticed under Windows XP with an ATI RADEON X800 PRO installed. Further information on this issue can be found at: http://www.ati.com/support/infobase/4578.html
Indian Jones and the Emperors Tomb: Display corruption and missing polygons are noticed in the game. Further information on this issue can be found at: http://www.ati.com/support/infobase/4563.html
PainKiller: missing textures is noticed on the ground and light artifacts are noticed when moving around within the game or when moving in and out of the light. This issue is known to occur under Windows XP when an ATI RADEON X800 XT is installed. Further information on this issue can be found at: http://www.ati.com/support/infobase/4579.html
Attempting to play a Java based game or visit a Java based website results in display corruption under Windows XP when either an ATI RADEON 9800 SE or RADEON X800 XT Platinum card installed and AA is enabled. Further information on this issue can be found at: http://www.ati.com/support/infobase/4570.html
מי צריך 4.8 שיש 4.9 בא שנותן ביצועים טובים יותר בדום 3 :xyxthumbs:
הרשימה המלאה כאן
http://www2.ati.com/drivers/Catalyst_48_release_notes.html
אני מתערב שזה כולל את ה "hotfix" לדום ושווה להתקין.
אפשר לקרוא שיש שם 12% שיפור בדום 3 :xyxthumbs:
OpenGL driver efficiency is also improved. Older OpenGL games such as Quake III Arena and Wolfenstein - Enemy Territory show small improvement (1-2%) at low resolutions. Call of Duty framerates are up approximately 4%. Doom3 improves considerably more (as much as 12% on some product configurations) as a result of the same software efficiency improvements.
יש יש בערך 12 אחוז שיפור
סוף סוף לקח להם יותר מידי זמן הפעם
אוף אם היו מטפלים בזה לפני הייתי הרבה הרבה הרבה יותר שמח , סבלתי מהבאג הזה הרבה מאוד
ואני מחכה יותר ל4.9 עם הממשק החדש נראה מגניב:)
הדרייבר שיפר לי ב400 נקדות ב3DMARK01 מה4.9B, קיבלתי 15K אם הדרייבר הנ"ל, מומלץ מאוד!
מה עדיף? 4.9B או זה לדום?
אוי ואבוי למי שמתקין את הדרייבר בלי להריץ קודם טיימדמו בדום ואחרי זה להשוות עם הדרייבר החדש.  >:(
סתם, קיצר אני רוצה לומר שיהיה מעניין אם יפרסמו פה כמה השוואות בטיימדמו.
5868 - catalyst 4.7
5968 - catalyst 4.8
שיפר ב100 נק ב3דמ 2003... בדריבר הבא נעבור את המחסום ה6000 ללא א"ק ! (לא לכרטיס ולא למעבד... )
(ר9800פרו...)
יום צוובבב
רבאק, מאז מאי יש להם את הבאג הזה ב-City of Heroes, מאז יצאו כבר 4 גרסאות דרייברים, כמה זמן לוקח למצוא ולתקן את זה ?!?!
זה ממש מעצבן !!!
nadaw איזה כרטיס מסך יש לך ?
5868 - catalyst 4.7
5968 - catalyst 4.8
(ר9800פרו...)
יום צוובבב
הוא רשם למטה R9800P  :xyxthumbs:
5868 - catalyst 4.7
5968 - catalyst 4.8
(ר9800פרו...)
יום צוובבב
תוצאה יפה
מה שאר המערכת ?
שאר המערכת :
amd64 3000...
512 kingstone
80 wd sata
gigabyte ga-kvt800 pro
ועידכון !!!
עשיתי עוד מבדק ב3דמארק2003... וקיבלתי 6003 !!!!!!!!
עברתי את מחסום ה6K ללא א"ק לשום דבר במערכת !!!!
יפיייייי..!!
לילה צובבבב
