Please help me buy a new PC in Canada
hi i want to buy a mew pc but i dont sure about the parts
so i have 1000-1500 american dolars to spend on a pc that can hold realy havy games internet and multi aplications
i dont need nothing eccept the pc himself
im buying the pc in canada so give me advices about some good chep store there
tnx and bye
1,000.00 USD   =   1,306.46 CAD
1,500.00 USD   =   1,959.18 CAD
1 USD = 1.30612 CAD
Meaning your budget is somewhere between the 1305-1960 candian dollars.
Store: http://www.tigerdirect.ca
Complete Spec:
CP2-A64-3000 C :: AMD Athlon 64 3000+ / 512KB Cache / 1600MHz FSB / Socket 754 / Processor
         In Stock $307.99  $307.99
  T925-2030 :: ThermalTake Silent Tower / Socket A/478/754 / AMD Athlon XP up to 3400+/Intel Pentium 4 up to 3.2GHz/AMD Athlon 64 FX / Copper Tube Heatpipe / Copper Core / CPU Cooling Fan
         Usually Ships in 7 - 21 Days $60.99  $60.99
  A455-2102 :: Asus K8V Deluxe VIA Socket 754 ATX Motherboard / AGP 8X / Audio / Gigabit LAN / USB 2.0 / Firewire / Serial ATA / RAID
         In Stock $181.99  $181.99
  M56-5200 :: Mushkin Green Line Dual Channel 1024MB PC3200 DDR 400MHz Memory (2 x 512MB)
         In Stock $237.99  $237.99
  P450-8606 :: XFX GeForce 6800 / 128MB DDR / AGP 8X / Dual DVI / TV Out / Video Card
         Available While Supplies Last $433.99  $433.99
  P725-3018 :: Pioneer DVR-A07XLB / 8x4x12x DVD±RW / 24x24x40x CD-RW / Dual Format / DVD Burner
  A451-4200 :: Artec DHM-G48 / 16x DVD-ROM / Black / OEM DVD Drive
         In Stock $41.99  $41.99
  THD-1600A2 P :: Seagate 160GB / 7200 / 8MB / ATA-100 EIDE Hard Drive
         In Stock $174.99  $174.99
  T925-4002 :: ThermalTake Tsunami Series Aluminum ATX Mid-Tower Case with Clear Side, Top USB, Firewire and Audio Ports - Black
         Usually ships within 2 - 3 Days $165.99  $165.99
  V13-3000 :: Vantec 420Watt Stealth Aluminum Power Supply with 3 Cooling Fans
         Available While Supplies Last $111.99  $111.99
TOTAL $1,899.90 CA
I'm not sure how much the assembly costs there, but in Israel it's around the 200nis.
The products in this 'puter are really high quality, you can also save some places, maybe find a place that sell the GT version of the 6800, and get a better gaming expirence.
WHY NOT DVR-108 OR A08?
DVR 108 COSTS LESS THAN 150 IN THE US, DOES NOT LOOK NICE AS THE A07XL BUT HAS MUCH MORE FEATURES AND PROBABLY PERFORMS BETTER
cause this store doesn't have it maybe? :
This is Canada, not the US. If you got the extra time to search for him a store that does have it you're more than welcome to help him.
They also got plextor's and TDK, but didn't see a real need to upgrade there..
The TDK got X12 and costs 213$ CA, but i dont think it's really needed..
Shame they dont stock the LG and the NEC..
this would be a very nice system:
  PC Builder Quotation # 1601568
Category Image Item Description In Stock QTY Price Ext. Price
Case  ANTEC SUPER LANBOY CASE ALUMINUM W/ WINDOW NO P/S 3X5.25 6X3.5
(SUPER LANBOY) (sku: 10999)  Yes  1 $115.56  $115.56
Processor  AMD ATHLON 64 3000+ PROCESSOR S754 2.0GHZ 512KB L2 CACHE RETAIL BOX
(AMD643000) (sku: 11100)  Yes  1 $252.81  $252.81
Motherboard  MSI K8N NEO PLATINUM NFORCE3 250GB S754 5PCI SATA 1394 SOUND 1000LAN
(K8N-NEO-PT) (sku: 12061)  Yes  1 $190.66  $190.67
Memory  OCZ 512MB PC3200 DDR400 CAS2 3-3-6 184PIN W/ COPPER HEAT SPREADER
(OCZ400512R3) (sku: 12013)  Yes  2 $148.76  $297.53
IDE Hard Drives  WD CAVIAR SE 120GB SATA 7200RPM 8.9MS 8MB 3YR WARRANTY
(WD1200JD) (sku: 10005)  Yes  1 $133.40  $133.40
Floppy  1.44 MB High Density Floppy Drive
(FD144) (sku: 1712)  Yes  1 $10.50  $10.50
Video Card   MSI NX6800GT GEFORCE 6800 GT 256MB GDDR3 AGP8X VGA DVI-I TV OUT
(NX6800GT-TD256) (sku: 12432)  No  1 $604.55  $604.55
Power Supply  THERMALTAKE TT-480APD 480W POWER SUPPLY DUAL FAN MANUAL/TEMP. CONTROLLED
(W00013) (sku: 9665)  Yes  1 $106.84  $106.84
Keyboard  MICROSOFT MULTIMEDIA KEYBOARD & OPTICAL MOUSE OEM (WITH SYSTEM ONLY)
(K96-00001) (sku: 8484)  Yes  1 $33.91  $33.91
Optional Fans  ANTEC BLUE LED LIGHTED 80MM CHASSIS FAN 2600RPM 34CFM 30DBA
(BLUE LED 80MM FAN) (sku: 8273)  Yes  1 $12.00  $12.00
DVD Writer   PIONEER DVD+-RW 16X4X16 DUAL LAYER+R 4X CDRW 32X24X40 INT IDE WO/ SW
(DVR-A08XLA) (sku: 12457)  No  1 $143.75  $143.75
    Full assembly and testing of the system.  $50.00
YOUR TOTAL
All quoted prices are in CANADIAN DOLLARS
$1,951.51
if you cannot afford the few extra dollars you can always take a higher cas memory or take a via chipset mobo
system is from www.ncix.com in canada
edit: you should add even a cheap cd reader to enlengthen the life of your beatifull pioneer A08XLA.
thnx
youre awsome!!!
you're most welcomed :xyxthumbs:
the pioneer 108 should arrive to stock any day now at ncix
regarding the DVD writewr they write it is the A08XLA but on the same line no software which is very confusing. don;'t be sdurprised if you getr the DVR108 instead of the A08. but that is a small problem. you have a cover on your case anyway
you should also verify with them on the phone which fans are included with their case. i've added an 80 mm fan but you might need more.
the amd box should come with a good cooler. just verify it is a box like they write and not a tray
:hi:
The Antec comes with two 120mm fans, front and back, more than enough.
Great system integral.
