Project: Deus ex - Full PC; /!\ 56K/!\ Project Finished ! 200 PICs ! =>>
Hi all
I'm currently on vacations in France, on the border of switzerland - what means ~10 minutes from Geneva.....
Great computer shops there !!
here is a project that i started on the 15.4.04
and was finished a bit later....
what means that it is a project was done before 4 months
ENJOY
Here is a DEMO for the window:
based on that:
I finished the sleeving & the window
starting with some pics of fireworks of  56th Independence day of Israel - this evening:
mod pictures following:
Tomorrow will update with window continuation,
and probably case modification for painting in the following days...
All window is DONE !!!!!
I think I did an AMAZING job, and the lighted window is just..... :
30  PICs !!!!
ENJOY !!!!
OK-  this is not a pencil, it is a special tool with sharp point, it is used to note and write on hard materials.
I used it to do a guidance line for the dremel...
you'll see it again in following pics
OK  -  STOP !
now I need help for choosing the color of LED that will light it !
I just cant choose !!! they're all AMAZING colors !!
Dont forget that the case color will be shiny BLACK !
so blue is typical, and light quite bright, :
now it is blue, but with special green, it can be nice...
it can be the same color as the color of water....
(only blue led is far from color of water)  :
the red is very very bright ! but I dont know if it will be a good color.... :
green is also bright.... :
and the really, but       R E A L L Y   irresistible and AMAZING purple - (one red and one blue LED)
just got back with some cans of black spray paint,
started to sand again and again all the panels,
but you'll see in the pics - for the top panel, I tried sanding with 400-grit and water, after less than a minute it got unbelievable smooth (white) !!!
I will give some try with sanding the black (not the case) and other techniques....
I'm supposed to wait 24H between each layer, so tomorrow Ill continue...
while painting, I was saying to myself.... 'All these small annoying flying things crashing into the fresh-painted case..... YUCK !'
enjoy !
the windowed side panel is ready, and now is installed with all parts....
rest of the case will be ready tomorrow, and i will continue with rest of modding
so here's the side panel, just that there, and putting those together... that here and this thing to...ummmm....  :eyebrow:
good saturday morning !!
so i painted that locks and now all is back to place !
hardware as i said probably this week. cant wait anymore...  :
so as i said, got back with the hardware - except VGA card...
1   PMI 512MB DDR 400MHz PC3200 Gold 2-3-2-6
1   ELSA FALCOX 980FX PRO ATI RADEON 9800 PRO 128MB
1   Creative Inspire 4400 (4.1) black
1   ABIT NF7-SL ver 2.0 Nforce 2 AMD
1   Compucase Midi Tower CI-6A19 Black
- מאוורר נוסף למארז : Vantec ThermoFlow 120MM Smart
1   Thermalright ALX-800 for AMD
1   AMD ATHLON XP 2600
1   LG DVD 16x48 Black OEM
1   WD 120GB 7200RPM 8MB
1   Vantec Uv 80MM Case Fan Blue VAUVB
58 pics !
ENJOY !!!!
Hi all !
I hope very much that all of you loved this project !!     :hip:
the last picture here is the 204th one, so 204 PICS * 130k ea/  =  26.5 MB
can you believe that you have just downloaded 26mb ?  :wallbash:    :clap:
the computer has already been delivered to Liz, and she is happy with it   :P
  • תגובות 43
  • צפיות 10.4k
אבנר, כמו שאמרתי לליז (זה המארז שלה....) זה נראה ממש פצצה! (אמרתי גם לך אחרי התרד בביט-טק- לא?)
החריטה יכלה להיות יותר "חדה" אבל הנושא מפצה על הכול 8)
איך בשוויץ על השאטל?
תהנה
הצביעה יצאה לא אחידה..
החריטה לא חדה..
בכללי מוד מעולה ומושקע
WOW!!! :o איזה יופי! :D
זה רק אצלי או שחלק מהתמונות אי אפשר לראות ורואים חצי תמונה
לכמה אובר הגעת (או שהיא הגיע) עם האלקס 800???
ולמה לא לקחת ישר מארז שחור?
את החריטה עשית על הצד ההפוך??
ושוויץ שולטת!!!
איתן
יצא ממש נחמד..
מצטרף לשאלה למה המארז לא נקנה שחור עם צביעה נקייה יותר?
אבל בקיצור חוץ מהמארז אהבתי הכל! קבל ח"ח :P
עוד משהו שאני חייב לציין השילוב של האדום והכחול----AMAZING!!!!!
זה הצבע לGLOWPAD הבא שלי.... ;)
כמה MCD הלדים האלה ומאיפה???
איתן
WOW יפה !
can i ask you why are you writeing in english?
in the icq i was talking to you in hebrew....
WOW
אחרי שצפיתי ברוב התמונות
אני חייב להודות התרשמתי לטובה
אחלה השקעה ואחלה ביצוע
תתחדש על המחשב החדש
פפפפפפשש איזה יופי...
וואי מרשים מאוד מרשים מאוד מאוד.
תגיד את המעלות במארז?
החריטה לא על הצד ההפוך, ולא, זה לא היה נראה יותר טוב...
אלו לדים של בערך 6000-8000 mcd שאני מביא מחו"ל ומוכר לחנות בשם כלשהו...
בשוויץ ממש ממש מדהים, באזור ז'נבה, המקום הכי יפה עלי אדמות
המארז השחור לא היה במלאי ולא היה צפוי להגיע
UNBELIVEABLE
I CANT BELIVE IT
איזה יופי
יצא לך מאוד יפה
תתחדש ותהנה מהחשב הזה
