hello i have problem with newegg so im build other mifrat from pandas need deaot
shalom ani ahshav be U.S.A
vekol hainyan aim liknot bnewegg kvar lo tov biglal kol hketa shel hhahrayot hhorim doagim =\
az hem rochim lkinot li at ze b-pandas tagido li aih hmifrat hze lmishakim hazakim aval mmas hazakim kmo far cry condition zero vekol hmishakim hhadashim..
az hine hmifrat tagido ma dathem
1 AMD ATHLON 64 3200+ OEM 1,757 ש"ח
1 Thermaltake Venus 12 CPU Cooler for AMD Opteron / Athlon-64 170 ש"ח
1 EPoX EP-8HDA3+ VIA K8T800 754-pin 709 ש"ח
1 OCZ 1GB (512X 2) EL DDR PC3200 400mhzPlatinum Edition 1,790 ש"ח
1 Samsung 120GB 7200 RPM SATA 150 645 ש"ח
1 MSI 9800 PRO 128MB 1,390 ש"ח
1 LITE-ON DVD 16*48 Retail Black 223 ש"ח
1 MITSUMI 3.5 FLOPPY DISK DRIVE - 1.44 BLACK 71 ש"ח
1 RAIDMAX Scorpio 668 Aluminium Black 420 Watt 955 ש"ח
1 Thermaltake Butterfly Purepower 480W 550 ש"ח
1 Arctic-Cooling VGA Silenser Ver.3 115 ש"ח
1 הרכבת מחשב במעבדה 185 ש"ח
bekesher lmaraz ani mvakesh zikoy lhorid at hsapak koh vani kone aod mavrerim lmaraz
ani metahnen overclock katan lkartis masah veaoly gam lamabed aval aval bshalav yoter maohar
ah vemisho mohan lagid li aim pandas hem aminim vafshar lismoh alihem beksher lkol hketa shel hahrayot
toda mirash
nadav
אתה יודע אתה יכול לרשום בעברית
והמפרט נראה בסדר
ani lo yahol ani barchot hbrit vemaifo shani kotev ain afsharot lhtov bevrit hol mikre lo meshana ..
veani lo ktavti bevrit ani heatakti mpanda..
vemisho yoda aim hmsi 9800pro 128mb bepanda ho aim 256bit
ki lo katov sham yoter miday pratim
veatem hoshvim shze nahon shdom3 doresh 256MB bkartis masah?!?!?
thanks =)
couldnt you add hebrew support in windows? ::)
EPOX 8KDA3J is a better board for overclocking
via k8t800 chipset is bad in overclocking
corsair twinx pc4000 1024mb costs about same price as the ocz way better for overclocking
if youll change the hdd to wd 120gb sata 8mb which is 165 nis cheaper,remove the dvd,downgrade psu to tt 420 pfc ,youll be able to buy a dvd burner
i recommend this one : http://www.yardenpc.co.il/Product.asp?productid=723&catcode=63
the msi r9800 pro is 256 bit,you can see that if youll click the link to the product page
doom3 requires a 512mb graphic card to run at maximum settings
looks great
i wouldn't take this case, i would take the Compucase 6A19 with that TT butterfly P/S or somewhat HEC 475W P/S/
and about the CPU - ask them to give you the 512k cach or the 1MB cach - read about them a little bit/
there are only 2 versions of a64 3200 so hes gonna get one of em eitherway
the 3200 newcastle 512kb cache is better its clocked 2.2GHZ and the clawhammer 1mb is clocked 2ghz
[pre]Ron
THANK YOU FOR THE LG CREDIT ;)[/pre]
if u r thinking about new and heavy games
so buy the card in the US
take the 6800GT 256mb
for 390$
it will be around 1800shekel
and in israel it will cost u 2600 shekel
and the other parts buy in israel when u will come.
its my best advice for you.
get a good video card there.
maybe even the memory
OCZ got an life time international warrenty
so u could get it there and if something happens u can use the warrenty here
as i know it.
גופי קירור תקנה בארה"ב, אני בספק אם תצטרך אחריות על חתיכת נחושת\אלומיניום גדולה
יש בnewegg את הhyper 6 ב-55 דולר, זה אחלה מחיר, והוא לוקח בקלות את הקירור ששמת
וגם את הסיילנסר ב-16 דולר
