למה, למה ציון כזה נמוך (2028) ב- 3dmark03
נתונים:
CPU Info
CPU 1/1
AMD AMD Athlon XP 2000+ 1.7 GHz
Manufacturer   AMD
Family   AMD Athlon XP 2000+
Internal Clock   1.7 GHz
Internal Clock Maximum   1.7 GHz
External Clock   133.0 MHz
Socket Designation   Socket A
Type   Central
Upgrade   ZIF Socket
Capabilities   MMX, CMov, RDTSC, 3DNow!, Extended 3DNow!, SSE
Version   AMD Athlon XP 2000+
Caches
Level 1    128 KB
Level 2    256 KB
DirectX Info
Version   9.0
Long Version   4.09.00.0902
DirectDraw
Version   5.3.0000000.900
Primary Device   NVIDIA GeForce FX 5700LE (Omega 1.5303)
Display Device 1/1
NVIDIA GeForce FX 5700LE (Omega 1.5303)        Driver 5.3.0.3
Description   NVIDIA GeForce FX 5700LE (Omega 1.5303)
Manufacturer   NVIDIA (Omega 1.5303)
Total Local Video Memory   256 MB
Total Local Texture Memory   256 MB
Total AGP Memory   128 MB
Driver File   nv4_disp.dll
Driver Version   5.3.0.3
Driver Date   11-17-2003
Driver WHQL Certified   false
Max Texture Width   4096 px
Max Texture Height   4096 px
Max User Clipping Planes   6
Max Active Hardware Lights   8
Max Texture Blending Stages   8
Fixed Function Textures In Single Pass   8
Vertex Shader Version   2.0
Pixel Shader Version   2.0
Max Vertex Blend Matrices   0
Max Texture Coordinates   8
VGA Memory Clock   85.5 MHz
VGA Core Clock   45.0 MHz
PCI
Name   NVIDIA GeForce FX 5700LE (Omega 1.5303)
Vendor ID   0x10de
Device ID   0x0343
SubSystem ID   0x00000000
Revision ID   0xa1
Texture Formats
32-bit ARGB [8888]
32-bit RGB [888]
16-bit RGB [565]
16-bit RGB [555]
16-bit ARGB [1555]
16-bit ARGB [4444]
8-bit YUV [800]
16-bit AYUV [8800]
FourCC [DXT1]
FourCC [DXT2]
FourCC [DXT3]
FourCC [DXT4]
FourCC [DXT5]
Memory Info
Total Physical Memory   384 MB
Free Physical Memory   170 MB
Total Pagefile Memory   923 MB
Free Pagefile Memory   721 MB
Memory Array 1/1
Max Module Capacity   256 MB
Use   Video
Supported Speeds
Supported Types
Supported Voltages
Memory Slot 1/4
Installed Enabled Size   256 MB
Form Factor   DIMM
Frequency   0.0 Hz
Slot   A0
Manufacturer   <unknown>
Type Details
Enabled Size   256 MB
Total Bit Width   0 b
Data Bit Width   0 b
Memory Slot 2/4
Installed Enabled Size   128 MB
Form Factor   DIMM
Frequency   0.0 Hz
Slot   A1
Type Details
Enabled Size   128 MB
Total Bit Width   0 b
Data Bit Width   0 b
Memory Slot 3/4
Installed Enabled Size   0 B
Frequency   0.0 Hz
Type Details
Enabled Size   0 B
Total Bit Width   0 b
Data Bit Width   0 b
Memory Slot 4/4
Frequency   0.0 Hz
Type Details
Enabled Size   0 B
Total Bit Width   0 b
Data Bit Width   0 b
Motherboard Info
Manufacturer   BIOSTAR Group
Model   M7VIB
Version
BIOS Vendor   Award Software International, Inc.
BIOS Version   BIOSTA - 42302e31
BIOS Release Date   24/04/02
BIOS Properties   Plug and Play, Flash, AGP
AGP
Revision   2.0
Rate   1x, 2x, 4x (4x enabled)
Available Rate   0x00000007
Selected Rate   0x00000004
Aperture Size   128 MB
Sideband Addressing   supported (enabled)
Fast Write   not supported
Card Slots
Slot 1/6 (PCI)
Order   1
Designation   PCI-1
Type   PCI
Characteristics
Data Bus Width   32 b
Details   Available, Long
IRQ   0
Slot 2/6 (PCI)
Order   2
Designation   PCI-2
Type   PCI
Characteristics
Data Bus Width   32 b
IRQ   0
Slot 3/6 (PCI)
Order   3
Designation   PCI-3
Type   PCI
Characteristics
Data Bus Width   32 b
IRQ   0
Slot 4/6 (PCI)
Generic SoftK56
Order   4
Designation   PCI-4
Type   PCI
Characteristics
Data Bus Width   32 b
Details   In Use, Long
Device Class   Modem
Manufacturer   Generic
Driver Version   5.0.0.2
Driver Date   7-1-2001
IRQ   11
Slot 5/6 (PCI)
Order   5
Designation   PCI-5
Type   PCI
Characteristics
Data Bus Width   32 b
IRQ   0
Slot 6/6 (AGP)
Order   0
Designation   AGP
Type   AGP
Characteristics
Data Bus Width   32 b
Device Class   Display Adapter
IRQ   11
System Devices
Name   VIA Tech PCI to ISA bridge
Manufacturer   VIA
Name   VIA Tech CPU to PCI Bridge
Manufacturer   VIA
Name   VIA CPU to AGP Controller
Manufacturer   VIA
Monitor Info
Monitor 1/1
Name   MAG XJ707
Manufacturer   MAG Technology Co., Ltd.
Max Width   1280 px
Max Height   1024 px
Operating System Info
Operating System   Microsoft Windows XP
Version   5.1.2600
Service Pack   Service Pack 1
Locale   IL
Desktop Width   1024 px
Desktop Height   768 px
Desktop BPP   32 b
Hard Disk Info
Hard Disk Drive 1/1
Name   WDC WD400BB-00DEA0
Manufacturer   (Standard disk drives)
Capacity   37.27 GB
Model   WDC WD400BB-00DEA0
Interface Type   IDE
בבקשה עזרו לי לדעת כיצד "אני יכול להשתפר"
החשוד העיקי שלי הוא הלוח... >:(
זה הכרטי סמסך...
הוא די חלש...
גם המעבד לא מאוד מהיר...
גם אין הרבה זכרון...
ובאמת הלוח לא משהו...
אני חושב שאתה תאלץ לשדרג אם אתה לא מרוצה מהביצועים.
לצערי כרגע אין אשרות כספית לשדרג :'(
אין דרכים במסגרת הקיים ? :-[
אולי OC למעבד ולכרטיס מסך...
וזה יכול לשנות משמעותית הביצועים ?
תלוי בOC.
אבל לפי היכולות שאני צופה למערכת, ובגלל שאתה לא יכול להשקיע כסף (למערכת קירור), הOC לא ילך מאוד רחוק...
זה הכרטיס מסך , טוב אנשים , לפחות אנחנו יודעים שFX5700LE שווה ערך לאיזה R9600NP... , לא רע...
תחשבו טוב , נגיד עם מחשב חזק , הוא היה נותן 2300-2400... , אז זה לא הכי רע בעולם בשביל 500-400שקל...
