Windows 10 Office 16 במחירי רצפה
כאן זה משתמע אחרת -
https://answers.microsoft.com/en-us/windows/forum/windows_10-win_licensing/are-these-windows-activation-sites-like-scdkey/c1fe753b-445f-401f-a373-f60d6bece71d
מתוך האתר -
Replied on April 15, 2018
They might selling MSDN keys:
About MSDN or TechNet Product Keys
They are genuine Microsoft product keys, they are actually retail licenses, but it is intended for a particular product channel either the Microsoft Software Developer Network (MSDN) or TechNet for IT Professionals who pay a subscription fee. The main purpose is for evaluation purposes. The great thing about them, unlike trial Microsoft software, MSDN or TechNet keys don't expire. Because the agreement under which the subscription is provided is a single license, none of the software should be distributed outside of it. Even though its $50,000 worth of licenses, it is for one person only to use and no one else. Unfortunately, regardless of the licensing terms, persons still abuse the program, either giveaway product keys or resell it on auction sites. Microsoft licenses it in good faith that customers won't do so, but I guess human nature wins out.
In your case, what probably happened is, you bought an MSDN licensed key, which carries up to 10 activations unlike full packaged retail licenses which only carry 1 activation. The person who sold it to you probably sold it to 10 other persons. Somewhere along the way, one of those persons might have installed it on a second system, activated it, because it went past 10 activation threshold, Microsoft detected it that it was being abused and blocked the key from further use.
Best,
Andre
Windows Insider MVP
MVP-Windows and Devices for IT
twitter/adacosta
groovypost.com
https://www.thewindowsclub.com/is-it-legal-to-use-the-cheap-windows-10-keys-available-on-the-internet-do-they-work
  • תגובות 68
  • צפיות 8.3k
לדעתי מיקרוסופט מעדיפה את התחום האפור הזה מבחינה משפטית ע"י פני פריצות אין סופיות של WIN 10.
בקיצור, שכל אחד יעשה מה שטוב לו עם הכסף שלו. אצלי כבר כמה שנים עם המפתח, עברתי... עדכונים ושינויים והכל תקין טפו, טפו...
ציטוט של urib
^^^^^   אלו מילות המפתח !
כלומר, יש למייקרוסופט אינטרסים משלה,
על מי ומתי להעלים עין, ועל מי "להתהפך" ....
ציטוט של urib
נכון.
אבל שיידע מה המשמעות של מעשיו,
ולא יחיה באשליה וישאל שאלות כמו שנשאלו כאן.
הנה, עוד זווית של העניין, ממש לא חייבים לראות את כל הבלה בלה בלה,
תיגשו ישירות לדקה העשירית ...
https://www.youtube.com/watch?v=yXTqz3Fd28M
יום טוב ובריאות לכולנו !
בקיצור אם מיקרוסופט תתהפך עליכם... תקלידו בשורת החיפוש את הפקודה "slui 04", ומשם תקבלו הנחיות דרך הטלפון... לפתור את הבעיה.:party0043:
ציטוט של urib
סוף מעשה במחשבה תחילה .....
ציטוט של urib
עדכון:
התקשרתי לפני כמה דקות לתמיכה של MS, לבעיה במערכת במחשב של הבן שלי (רק ניסיון)...
לאחר עימות של המפתח שנרכש מאתר סיני! אושרתי על ידם כמשתמש חוקי לכל דבר.
נאפו קראת את זה?
אם הוא אושר כמשתמש חוקי מה אתה ממשיך לקשקש שחיים באשליה.
"משמע מכאן משמע משם", שום דבר רשמי ממיקרוסופט לא ראיתי, חוץ ממה שURIB כתב שזה הכי קרוב לזה, ואם אישרו אותו אז מה לא בסדר? שזה לא תואם להגיון המוסרי שלך?
נערך על-ידי No-One
ציטוט של No-One
זה לא תואם את המציאות המשפטית של מייקרוסופט עצמם !
ציטוט של napoleon45
Best,
Andre
Windows Insider MVP
לנוחותך ותשומת ליבך !
ומה אני ומצפוני שייך לכאן ?  :nixweiss:
אני לחלוטין מסכים עם @napoleon45. אבל אם זה מרגיע אתכם, מיקרוסופט לא תיפול עליכם. פשוט לא משתלם לה להתחיל לתבוע משתמשים ביתיים, ועוד מחוץ לארה"ב...
אבל עסקים... זה כבר סיפור אחר. השמועות אומרות שיש להם רשימות מדויקות של מפתחות לא חוקיים, והם פשוט מתעלמים. כמו שנאמר כאן כבר, אפשר להתשמש בWINDOWS אפילו בלי אקטיבציה (אם לא אכפת לך מהאזהרה והעדכונים). מיקרוסופט יודעים שאין להם מה לעשות, פשוט.
ציטוט של af db creid
זה לא נכון, מדובר באתרים שמוכרים מפתחות חוקיים כצד שלישי, אני לא מבין מה הבעיה פה.
אם מיקרוסופט הייתה מעוניינת לתבוע, היא הייתה ממזמן סוגרת לאתרים האלו את הבאסטה...
ברור שיש אתרים נוכלים שבאת יכולים לדפוק את הלקוח, כמו בכל תחום יש נוכלים.
מה הבעיה לקנות באתר הזה במקום 680 ש"ח בארץ?
נערך על-ידי urib
ציטוט של urib
:kopfpatsch:
ציטוט של napoleon45
אז לפי התפיסה שלך, כל החנויות האלו רמאים, שקרנים, גנבים... ורק בארץ הקודש מותר לגנוב מהצרכן 600-700 ש"ח.
ציטוט של urib
שוב, ושוב ושוב ...
מה אני קשור ?
כאילו אני תבעתי את העסקים בארץ ....
תקרא את הנאמר באנגלית בציטוטים לעיל.
האתרים הם רסללרים ( כדי להימנע מתביעה )  כמו כל אתרי תוכנות פרוצות ...
האחריות מוטלת על הצרכן, לא על מי שמכר , זה ה - EU  ב - EULA.
ירצו, יתבעו, לא ירצו  לא.
תיכף תגיד  גם, "מה, השתגעתי לשלם על WINRAR ?" ....
אבל גם היא לא חינמית, למרות שהכיפה שואפת לאפס.
מאיפה לעזאזל אתה קובע שהחנויות האלו לא מוכרים מפתחות חוקיים? יש לך הוכחות?
זה כמו שתרכוש משחק מבאג במחיר מופקע, במקום לקנות מחנות דיגיטלית כגון: GMG
אל תענה לי... התעייפתי כבר מהדיון הזה.:s0403:
נערך על-ידי urib
