כמה מגה הכרטיס מסך שלי פרטים בפנים
SiSoftware Sandra
Video Adapter
Model : NVIDIA RIVA TNT2 Model 64
Chipset : RIVA TNT2 Model 64
RAMDAC : Integrated RAMDAC
Video BIOS : Version 2.05.1112
VGA Compatible : No
Total Memory : 32MB (32MB Video)
Texture Memory : 64MB
Supports DIME Texturing : Yes
AGP Capabilities
Version : 2.00
Command Queue Length : 32
Fast-Writes Enabled : No
Side Band Enabled : No
Data Transfer Modes Support : 1x 2x 4x
Current Data Transfer Rate : 2x
Video BIOS
Date : 01/18/00
Version : 2.05.11125
Current Video Mode
Mode : 800x600 64K HiColour (16-bit)
Current Refresh Rate : 85Hz
Virtual Desktop Size : 800x600
Video Driver
Model : nv4.sys
Version : 5.01.2001.1240
Expected Windows Version : 4.00
Video Acceleration : Yes
Screen Saver Active : 10 minutes(s)
Screen Saver Name : D:\WINDOWS\System32\logon.scr
Low Power Saving Active : 20 minutes(s)
Power Off Saving Active : 20 minutes(s)
Supported Video Modes
Mode 0 : 640x480 256 colours (8-bit) 60Hz
Mode 1 : 640x480 256 colours (8-bit) 70Hz
Mode 2 : 640x480 256 colours (8-bit) 72Hz
Mode 3 : 640x480 256 colours (8-bit) 75Hz
Mode 4 : 640x480 256 colours (8-bit) 85Hz
Mode 5 : 320x200 256 colours (8-bit) 60Hz
Mode 6 : 320x200 256 colours (8-bit) 70Hz
Mode 7 : 320x200 256 colours (8-bit) 72Hz
Mode 8 : 320x200 256 colours (8-bit) 75Hz
Mode 9 : 320x240 256 colours (8-bit) 60Hz
Mode 10 : 320x240 256 colours (8-bit) 70Hz
Mode 11 : 320x240 256 colours (8-bit) 72Hz
Mode 12 : 320x240 256 colours (8-bit) 75Hz
Mode 13 : 400x300 256 colours (8-bit) 60Hz
Mode 14 : 400x300 256 colours (8-bit) 70Hz
Mode 15 : 400x300 256 colours (8-bit) 72Hz
Mode 16 : 400x300 256 colours (8-bit) 75Hz
Mode 17 : 512x384 256 colours (8-bit) 60Hz
Mode 18 : 512x384 256 colours (8-bit) 70Hz
Mode 19 : 512x384 256 colours (8-bit) 72Hz
Mode 20 : 512x384 256 colours (8-bit) 75Hz
Mode 21 : 640x400 256 colours (8-bit) 60Hz
Mode 22 : 640x400 256 colours (8-bit) 72Hz
Mode 23 : 640x400 256 colours (8-bit) 75Hz
Mode 24 : 640x400 256 colours (8-bit) 85Hz
Mode 25 : 640x400 256 colours (8-bit) 100Hz
Mode 26 : 640x400 256 colours (8-bit) 120Hz
Mode 27 : 800x600 256 colours (8-bit) 60Hz
Mode 28 : 800x600 256 colours (8-bit) 70Hz
Mode 29 : 800x600 256 colours (8-bit) 72Hz
Mode 30 : 800x600 256 colours (8-bit) 75Hz
Mode 31 : 800x600 256 colours (8-bit) 85Hz
Mode 32 : 1024x768 256 colours (8-bit) 60Hz
Mode 33 : 1024x768 256 colours (8-bit) 70Hz
Mode 34 : 1024x768 256 colours (8-bit) 72Hz
Mode 35 : 1024x768 256 colours (8-bit) 75Hz
Mode 36 : 1024x768 256 colours (8-bit) 85Hz
Mode 37 : 1152x864 256 colours (8-bit) 60Hz
Mode 38 : 1152x864 256 colours (8-bit) 70Hz
Mode 39 : 1152x864 256 colours (8-bit) 72Hz
Mode 40 : 1152x864 256 colours (8-bit) 75Hz
Mode 41 : 1280x960 256 colours (8-bit) 60Hz
Mode 42 : 1280x1024 256 colours (8-bit) 60Hz
Mode 43 : 640x480 64K HiColour (16-bit) 60Hz
Mode 44 : 640x480 64K HiColour (16-bit) 70Hz
Mode 45 : 640x480 64K HiColour (16-bit) 72Hz
Mode 46 : 640x480 64K HiColour (16-bit) 75Hz
Mode 47 : 640x480 64K HiColour (16-bit) 85Hz
Mode 48 : 320x200 64K HiColour (16-bit) 60Hz
Mode 49 : 320x200 64K HiColour (16-bit) 70Hz
Mode 50 : 320x200 64K HiColour (16-bit) 72Hz
Mode 51 : 320x200 64K HiColour (16-bit) 75Hz
Mode 52 : 320x240 64K HiColour (16-bit) 60Hz
Mode 53 : 320x240 64K HiColour (16-bit) 70Hz
Mode 54 : 320x240 64K HiColour (16-bit) 72Hz
Mode 55 : 320x240 64K HiColour (16-bit) 75Hz
Mode 56 : 400x300 64K HiColour (16-bit) 60Hz
Mode 57 : 400x300 64K HiColour (16-bit) 70Hz
Mode 58 : 400x300 64K HiColour (16-bit) 72Hz
Mode 59 : 400x300 64K HiColour (16-bit) 75Hz
Mode 60 : 512x384 64K HiColour (16-bit) 60Hz
Mode 61 : 512x384 64K HiColour (16-bit) 70Hz
Mode 62 : 512x384 64K HiColour (16-bit) 72Hz
Mode 63 : 512x384 64K HiColour (16-bit) 75Hz
Mode 64 : 640x400 64K HiColour (16-bit) 60Hz
Mode 65 : 640x400 64K HiColour (16-bit) 72Hz
Mode 66 : 640x400 64K HiColour (16-bit) 75Hz
Mode 67 : 640x400 64K HiColour (16-bit) 85Hz
Mode 68 : 640x400 64K HiColour (16-bit) 100Hz
Mode 69 : 640x400 64K HiColour (16-bit) 120Hz
Mode 70 : 800x600 64K HiColour (16-bit) 60Hz
Mode 71 : 800x600 64K HiColour (16-bit) 70Hz
Mode 72 : 800x600 64K HiColour (16-bit) 72Hz
Mode 73 : 800x600 64K HiColour (16-bit) 75Hz
Mode 74 : 800x600 64K HiColour (16-bit) 85Hz
Mode 75 : 1024x768 64K HiColour (16-bit) 60Hz
Mode 76 : 1024x768 64K HiColour (16-bit) 70Hz
Mode 77 : 1024x768 64K HiColour (16-bit) 72Hz
Mode 78 : 1024x768 64K HiColour (16-bit) 75Hz
Mode 79 : 1024x768 64K HiColour (16-bit) 85Hz
Mode 80 : 1152x864 64K HiColour (16-bit) 60Hz
Mode 81 : 1152x864 64K HiColour (16-bit) 70Hz
Mode 82 : 1152x864 64K HiColour (16-bit) 72Hz
Mode 83 : 1152x864 64K HiColour (16-bit) 75Hz
Mode 84 : 1280x960 64K HiColour (16-bit) 60Hz
Mode 85 : 1280x1024 64K HiColour (16-bit) 60Hz
Mode 86 : 640x480 16M+ TrueColour (32-bit) 60Hz
Mode 87 : 640x480 16M+ TrueColour (32-bit) 70Hz
Mode 88 : 640x480 16M+ TrueColour (32-bit) 72Hz
Mode 89 : 640x480 16M+ TrueColour (32-bit) 75Hz
Mode 90 : 640x480 16M+ TrueColour (32-bit) 85Hz
Mode 91 : 320x200 16M+ TrueColour (32-bit) 60Hz
Mode 92 : 320x200 16M+ TrueColour (32-bit) 70Hz
Mode 93 : 320x200 16M+ TrueColour (32-bit) 72Hz
Mode 94 : 320x200 16M+ TrueColour (32-bit) 75Hz
Mode 95 : 320x240 16M+ TrueColour (32-bit) 60Hz
Mode 96 : 320x240 16M+ TrueColour (32-bit) 70Hz
Mode 97 : 320x240 16M+ TrueColour (32-bit) 72Hz
Mode 98 : 320x240 16M+ TrueColour (32-bit) 75Hz
Mode 99 : 400x300 16M+ TrueColour (32-bit) 60Hz
Mode 100 : 400x300 16M+ TrueColour (32-bit) 70Hz
Mode 101 : 400x300 16M+ TrueColour (32-bit) 72Hz
Mode 102 : 400x300 16M+ TrueColour (32-bit) 75Hz
Mode 103 : 512x384 16M+ TrueColour (32-bit) 60Hz
Mode 104 : 512x384 16M+ TrueColour (32-bit) 70Hz
Mode 105 : 512x384 16M+ TrueColour (32-bit) 72Hz
Mode 106 : 512x384 16M+ TrueColour (32-bit) 75Hz
Mode 107 : 640x400 16M+ TrueColour (32-bit) 60Hz
Mode 108 : 640x400 16M+ TrueColour (32-bit) 72Hz
Mode 109 : 640x400 16M+ TrueColour (32-bit) 75Hz
Mode 110 : 640x400 16M+ TrueColour (32-bit) 85Hz
Mode 111 : 640x400 16M+ TrueColour (32-bit) 100Hz
Mode 112 : 640x400 16M+ TrueColour (32-bit) 120Hz
Mode 113 : 800x600 16M+ TrueColour (32-bit) 60Hz
Mode 114 : 800x600 16M+ TrueColour (32-bit) 70Hz
Mode 115 : 800x600 16M+ TrueColour (32-bit) 72Hz
Mode 116 : 800x600 16M+ TrueColour (32-bit) 75Hz
Mode 117 : 800x600 16M+ TrueColour (32-bit) 85Hz
Mode 118 : 1024x768 16M+ TrueColour (32-bit) 60Hz
Mode 119 : 1024x768 16M+ TrueColour (32-bit) 70Hz
Mode 120 : 1024x768 16M+ TrueColour (32-bit) 72Hz
Mode 121 : 1024x768 16M+ TrueColour (32-bit) 75Hz
Mode 122 : 1024x768 16M+ TrueColour (32-bit) 85Hz
Mode 123 : 1152x864 16M+ TrueColour (32-bit) 60Hz
Mode 124 : 1152x864 16M+ TrueColour (32-bit) 70Hz
Mode 125 : 1152x864 16M+ TrueColour (32-bit) 72Hz
Mode 126 : 1152x864 16M+ TrueColour (32-bit) 75Hz
Mode 127 : 1280x960 16M+ TrueColour (32-bit) 60Hz
Mode 128 : 1280x1024 16M+ TrueColour (32-bit) 60Hz
Mode 129 : 640x480 16 colours (4-bit)
Mode 130 : 800x600 16 colours (4-bit)
System i2c Controller 1
Model : nVidia Riva GFX DDC1 i2c
Speed : 50kHz
System i2c Controller 2
Model : nVidia Riva GFX DDC2 i2c
Speed : 50kHz
Enhanced Video Settings
Animation Effects Enabled : Yes
Full Windows Drag Enabled : Yes
Font Smoothing Enabled : No
HighContrast Feature On : No
Device Mode Characteristics
Physical Medium Width : 320 mm, 13 in
Physical Medium Height : 240 mm, 9 in
Recommended CRT/Panel Size : 20 in
Horizontal/Vertical Resolution : 96x96 dpi
Colour Bits/Planes : 16 / 1 bit(s) pp
Brushes : 4294967295
Pens : 4294967295
Colours/Shades : 4294967295
Pixel Width/Height/Diagonal : 36 / 36 / 51
Driver Clipping Capabilities
Can Clip Output to Rectangle : Yes
Can Clip Output to Region : No
Driver Raster Capabilities
Supports Banding : No
Supports Fonts Larger than 64Kb : Yes
Can Transfer Bitmaps : Yes
Supports Bitmaps Larger than 64Kb : Yes
Supports Device Bitmaps : No
Supports DIBs : Yes
DIBs on Device Surface : Yes
Flood Fills : Yes
Supports Windows 2.x : Yes
Stretch/Compress Bitmaps : Yes
Stretch/Compress DIBs : Yes
Supports Scaling : No
Palette-Based Device : No
Saves Bitmap Locally : No
Driver Curve Capabilities
Can Draw Circles : Yes
Can Draw Ellipses : Yes
Can Draw Pie Wedges : Yes
Can Draw Chord Arcs : Yes
Can Draw Wide Borders : Yes
Can Draw Styled Borders : Yes
Can Draw Wide, Styled Borders : Yes
Can Draw Rounded Rectangles : Yes
Can Draw Interiors : Yes
Driver Line Capabilities
Can Draw Polylines : Yes
Can Draw Styled Lines : Yes
Can Draw Wide Lines : Yes
Can Draw Wide, Styled Lines : Yes
Can Draw Markers : Yes
Can Draw Polymarkers : Yes
Driver Polygonal Capabilities
Can Draw Alternate-fill Polygons : Yes
Can Draw Winding-fill Polygons : Yes
Can Draw Rectangles : Yes
Can Draw Scan Lines : Yes
Driver Text Capabilities
Supports Stroke Clip Precision : Yes
Supports Stroke Output Precision : Yes
Supports Character Output Precision : Yes
Supports 90° Character Rotation : No
Supports Any Angle Character Rotation : No
Supports Independent X-Y Scaling : No
Supports Doubled Character for Scaling : No
Supports Integer Multiples for Scaling : No
Any Multiples for Exact Scaling : No
Can Draw Double-Weighted Characters : No
Can Italicise : No
Can Underline : Yes
Can Draw Strikeouts : Yes
Can Draw Raster Fonts : Yes
Can Draw Vector Fonts : Yes
Cannot Scroll Using BitBlt : No
Performance Tips
Tip 314 : Video BIOS is too old. Check for an update.
Tip 322 : Turn off screen savers. Use the monitor power saving mode.
Tip 323 : Remove the desktop wallpaper to save memory and improve performance.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
יש לך 32 מגה. וחוץ מזה שהיה לי כרטיס כזה, אז אני יודע! ;)
