יש תוכנית יעודית להמהרת RADEON 8500LE?
מלבד PSTRIP.
מלבד PSTRIP.
RIVATUNER
מלבד PSTRIP.
RIVATUNER
תודה אבל לפי מה שמופיע באתר התוכנית, היא מיועדת לכרטיסי NVIDIA ולא ל-RADEON.
מלבד PSTRIP.
RIVATUNER
הגרסה החדשה תומכת
RivaTuner is the most powerful tweaking utility for NVIDIA display adapters running under Windows 98 / Windows 98 SE / Windows ME / Windows 2000 / Windows XP. The purpose of this utility is to give you access to the many undocumented features of Detonator drivers. All versions of Detonator drivers have a lot of undocumented registry entries. Some of them dont affect anything, but there are some that are very useful. In general, they cannot give you big performance boost but they can improve image quality and solve some compatibility problems. RivaTuner will help you to change all undocumented registry entries. It supports all versions of Detonators drivers starting from Detonator 2.08 under Windows 98 / Windows 98 SE / Windows ME (Detonator 5.08 or higher under Windows 2000 / Windows XP).
Now with GeForce4 and ATI Radeon 8500 support
