פורסם 2004 במרץ 2722 שנים Part type Part name ¤ Price Qty CPU : Intel Pentium IV 2.8C GHz HT 512K 800MHz Socket 478 CPU BOX [ ¤ 1091.38 ] 1 Motherboards for Intel : ABIT AI7 Intel 865PE Motherboard (µGuru,HT, FSB800,SATA RAID,Dual DDR,5.1 Sound,AGP8,LAN,1394,USB 2) [ ¤ 672.67 ] 1 Memory : GeIL DDR-RAM 256MB 2700 Value Memory w/Heat Spreader [ ¤ 277.18 ] 2 Hard Disks : Western Digital 120GB 7200 rpm 8MB Buffer Serial ATA HDD [ ¤ 638.47 ] 1 Video Cards : Sapphire Atlantis Radeon 9800 Pro 128MB DDR DVI Bulk Video Card [ ¤ 1529.95 ] 1 Floppy : Citizen Black 1.44MB 3,5" Floppy Drive [ ¤ 80.49 ] 1 CD-ROM / DVD-ROM : DVD-ROM Liteon 16/48 - Black ! [ ¤ 216.73 ] 1 CD-RW / DVD-RW : Lite-On 52/32/52 Black CD-RW [ ¤ 251.87 ] 1 Monitors : 17" LG F700P NEW Flatron Monitor + USB Hub [ ¤ 1083.11 ] 1 Keyboards : Microsoft Multimedia Keyboard + Optical Mouse KIT [ ¤ 143.82 ] 1 Cases : Raidmax Scorpio 868 Midi Tower Gaming Case ( P/S not included ) [ ¤ 402.81 ] 1 Power Supplies : ATX Power Supply 450 Watt for Pentium IV [ ¤ 120.29 ] 1 Subtotal : ¤ 6785.94 Part type Part name ¤ Price Qty CPU : AMD Athlon XP 2500+ Barton (512K, 333 Mhz) BOX CPU [ ¤ 529.27 ] 1 Motherboards for AMD : ABIT AN7 nForce2 Ultra400 Motherboard (µGuru,Dual DDR400, SATA RAID, 1394, 5.1 Sound, LAN, USB 2.0) [ ¤ 632.61 ] 1 Memory : GeIL DDR-RAM 512MB 3200 Value Memory w/Heat Spreader [ ¤ 528.22 ] 2 Hard Disks : Western Digital 120GB 7200 rpm 8MB Buffer Serial ATA HDD [ ¤ 638.47 ] 1 Video Cards : Sapphire Atlantis Radeon 9800 Pro 128MB DDR DVI Bulk Video Card [ ¤ 1529.95 ] 1 Floppy : Citizen Black 1.44MB 3,5" Floppy Drive [ ¤ 80.49 ] 1 CD-ROM / DVD-ROM : DVD-ROM Liteon 16/48 - Black ! [ ¤ 216.73 ] 1 CD-RW / DVD-RW : Lite-On 52/32/52 Black CD-RW [ ¤ 251.87 ] 1 Monitors : 17" LG F700P NEW Flatron Monitor + USB Hub [ ¤ 1083.11 ] 1 Keyboards : Microsoft Multimedia Keyboard + Optical Mouse KIT [ ¤ 143.82 ] 1 Cases : Raidmax Scorpio 868 Midi Tower Gaming Case ( P/S not included ) [ ¤ 402.81 ] 1 Power Supplies : ATX Power Supply 450 Watt for Pentium IV [ ¤ 120.29 ] 1 Subtotal : ¤ 6685.85 במפרט מבוסס אינטל יש מעבד יותר חזק שגם משתמש ב-dual ddr עם 2x256 זכרון ובשני יש מעבד פחות חזק של צל amd בלי-dual ddr אבל עם 512x2 זכרון איזה מחשב כדאי לי. תמליצו לי גם על מפרטים שונים המיועדים למשחקים אינטרנת ו-word במקסימו 6800 ש"ח תודה
פורסם 2004 במרץ 2722 שנים זה נראה כאילו אתה לא מעוניין באוברקלוק לפי הצרכים שלך ולפי הזכרונות שבחרת, אבל עדיין לקחת את הגירסה של לוחות האביט עם ה-uGuru.. תקח את הגירסאות הרגילה (IS7 ו-NF7-SL).תחליף את המקלדת ל-Genius 21E השחורה/כסופה ועכבר אופטי פשוט שחור של מיקרוסופט, יצא לך יותר זול מהקומבו הזה וגם שחור תואם.לקחת ספק ג'נרי מאפן, הוא לא באמת 450W.. ספק כח איכותי הוא מאוד חשוב תקח Thermaltake 360W, או אם יש לך את הכסף להשקיע את ה-420W.נראה לי שגם הייתי מעדיף את המארז של Chenbro שהוא יותר זול קצת, ולדעתי נראה פחות מצועצע.. (בטח גם יותר שקט עם פחות מאווררים).
