פורסם 2004 במרץ 1222 שנים http://www.amd-insight.de/main.php?cat=grafik&test=catalyst_comparison&page=1
פורסם 2004 במרץ 1222 שנים "So what can I tell you about the new Catalyst 4.3? The driver is very stable. There was no crash during the tests. All games ran without any artifacts or image failures (except Tomb Raider in 1600x1200 with 4xAA/16xAF).The performance is partly a little bit under the Catalyst 4.2 but sometimes the Catalyst 4.3 is a little bit faster than the Catalyst 4.2. The biggest performance gain gets the Catalyst 4.3 in games which use Pixelshader 2.0. One of them is Tomb Raider: Angel of Darkness".בקיצור לא כזה משנה 4.2 4.3 השאלה אם ATI תיקנו באגים חשובים ???
