מחשב קורס בזמן צפיה בSTREAMING
שלום
כשאני צופה בשידור סטרימינג ערוץ 2 ערוץ 10 או סתם ערוצים מהעולם אפילו YOUTUBE וזה רק בצפיה בסטרימינג אני מקבל מסך כחול עם השגיאה IRQL_NOT_LESS_REQUAL אז בדקתי עם MEMTEST והכל תקין לאחר 6 שעות בדיקה...
Microsoft ® Windows Debugger Version 6.3.9600.17029 AMD64
Copyright © Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
Symbol search path is: *** Invalid ***
* Symbol loading may be unreliable without a symbol search path. *
* Use .symfix to have the debugger choose a symbol path. *
* After setting your symbol path, use .reload to refresh symbol locations. *
Executable search path is:
* Symbols can not be loaded because symbol path is not initialized. *
* The Symbol Path can be set by: *
* using the _NT_SYMBOL_PATH environment variable. *
* using the -y <symbol_path> argument when starting the debugger. *
* using .sympath and .sympath+ *
*** ERROR: Symbol file could not be found. Defaulted to export symbols for ntkrnlmp.exe -
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff803`1aa87000 PsLoadedModuleList = 0xfffff803`1ad512d0
Debug session time: Fri Jul 25 15:32:15.772 2014 (UTC + 3:00)
System Uptime: 0 days 0:57:23.495
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000000`7f30a018). Type ".hh dbgerr001" for details
Loading unloaded module list
************* Symbol Loading Error Summary **************
Module name Error
ntkrnlmp The system cannot find the file specified
You can troubleshoot most symbol related issues by turning on symbol loading diagnostics (!sym noisy) and repeating the command that caused symbols to be loaded.
You should also verify that your symbol search path (.sympath) is correct.
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck A, {10, 2, 1, fffff8031aaff49e}
*** ERROR: Module load completed but symbols could not be loaded for mssmbios.sys
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: nt!_KPRCB ***
*** work. ***
*** work. ***
Probably caused by : ntkrnlmp.exe ( nt!RtlAvlRemoveNode+6e9a )
Followup: MachineOwner
2: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 0000000000000010, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
bit 0 : value 0 = read operation, 1 = write operation
bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff8031aaff49e, address which referenced memory
Debugging Details:
*** work. ***
*** work. ***
*** work. ***
ADDITIONAL_DEBUG_TEXT:
You can run '.symfix; .reload' to try to fix the symbol path and load symbols.
MODULE_NAME: nt
FAULTING_MODULE: fffff8031aa87000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 53388e13
WRITE_ADDRESS: unable to get nt!MmSpecialPoolStart
unable to get nt!MmSpecialPoolEnd
unable to get nt!MmPagedPoolEnd
unable to get nt!MmNonPagedPoolStart
unable to get nt!MmSizeOfNonPagedPoolInBytes
0000000000000010
CURRENT_IRQL: 0
FAULTING_IP:
fffff803`1aaff49e f00fba6f1000 lock bts dword ptr [rdi+10h],0
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
BUGCHECK_STR: AV
ANALYSIS_VERSION: 6.3.9600.17029 (debuggers(dbg).140219-1702) amd64fre
LAST_CONTROL_TRANSFER: from fffff8031abe6ae9 to fffff8031abdafa0
STACK_TEXT:
ffffd000`6ebfe4e8 fffff803`1abe6ae9 : 00000000`0000000a 00000000`00000010 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
ffffd000`6ebfe4f0 fffff803`1abe533a : 00000000`00000001 00000000`00000000 fffff6e8`00365000 ffffd000`6ebfe630 : nt!setjmpex+0x37e9
ffffd000`6ebfe630 fffff803`1aaff49e : fffff6fb`7dbed000 fffff6fb`7dbedf68 00000000`00000002 fffff803`1ab4577e : nt!setjmpex+0x203a
ffffd000`6ebfe7c0 fffff803`1ab021a1 : 80000000`d122d86f 80000000`d122d86f ffffd000`6ebfe910 fffff680`000ed8f0 : nt!RtlAvlRemoveNode+0x6e9a
ffffd000`6ebfe810 fffff803`1aed3060 : 00000000`0001db1e ffffd000`6ebfecc0 00000000`00000004 00000000`1db1efff : nt!RtlFindSetBits+0x17b9
ffffd000`6ebfea00 fffff803`1aed2d29 : ffffe000`c0273900 ffffe000`c35ac900 ffffd000`6ebfeb58 ffffd000`6ebfeb48 : nt!KeUserModeCallback+0x15c0
ffffd000`6ebfeb00 fffff803`1abe67b3 : ffffe000`c0273de8 00000000`7727902c fffff6fb`7dbed000 00000000`0008e4f8 : nt!KeUserModeCallback+0x1289
ffffd000`6ebfebd0 00007ffe`880db20a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!setjmpex+0x34b3
00000000`0008e4d8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffe`880db20a
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!RtlAvlRemoveNode+6e9a
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: ntkrnlmp.exe
BUCKET_ID: WRONG_SYMBOLS
FAILURE_BUCKET_ID: WRONG_SYMBOLS
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:wrong_symbols
FAILURE_ID_HASH: {70b057e8-2462-896f-28e7-ac72d4d365f8}
2: kd>
2: kd>
מה עוד לעשות?
נערך על-ידי I7210I
עידכון...ניסיתי לעשות שיחזור מערכת ואני מקבל את ההודעה הבאה..וזה אחרי שבMSCONFIG דאגתי שלא יעלה אנטי וירוס וגם נטרלתי אותו תוך כדי
http://jpg.co.il/view/53d27d0073530.jpg/
מה עוד לעשות???
איך בודקים איתה?
עם פתיחת התוכנה תראה טמפ' במרכז מימין. תסתכל על מסך זה בעת הפעלת הYOUTUBE אם מתחמם אתה תראה את הטמפ' עולה.
אם זה אכן טמפ' צריך לטפל בזה.
נערך על-ידי zelig192
איך אני יראה כשזה מתחמם עם המחשב קורס...?:)
תוך כדי הפעלת הyoutube תסתכלמדי פעם אם הטמפ' עולה. מדובר בעליה הדרגתית שתאפשר לך להתבונן בתוכנה.
בדקתי וזה עלה מ31 ל32.5 ואז קרס...זה בעיה אחרת משהו של תוכנה לדעתי
עדכן דרייברים bios chipset כ.מסך
הכל עדכני...
