פורסם 2004 במרץ 622 שנים ATI Radeon 9500 w / 128MB pro VGA card[VGAT1131] RADEON 9500 brings the world of Microsoft® DirectX® 9.0 support to gaming enthusiasts. Featuring incredibly fast 3D graphics performance, coupled with sophisticated real-time visual effects, unsurpassed image quality and cutting-edge video features, RADEON 9500 provides powerful graphics acceleration for current and next-generation games and applications. Complete Microsoft® DirectX® 9.0 support 128MB of DDR memory4-pixel pipeline architecture128-bit memory interfaceVideo output supportFeaturing CATALYST - Industry-leading software suiteFast 3D gaming performance 128MB DDR memory accelerates the latest 3D games 128-bit DDR memory interface provides end users with fast graphics performance 4-pixel pipeline architecture cuts rendering time in half when compared to any competing product Supports the new AGP 8X standard, providing a high-speed link between the graphics board and the rest of the PC (2.0 GB/sec) Highest level of realism Provides full support for Microsoft® DirectX® 9.0 and the latest OpenGL® functionality SMARTSHADER 2.0 technology allows users to experience complex, movie-quality effects in next-generation 3D games and applications SMOOTHVISION 2.0 technology enhances image quality by removing jagged edges and bringing out fine texture detail, without compromising performance 128-bit floating-point color precision allows for a greater range of colors and brightness Breakthrough video features ATI's latest FULLSTREAM technology removes blocky artifacts from streaming Internet video and provides sharper image quality Unique VIDEOSHADER engine uses programmable pixel shaders to accelerate video processing and provide better-looking visuals Products designed and built by ATI offer Hassle-free manufacturer's warranty Responsive and knowledgeable Customer Service Team Extensive online user resources and updates through ATI.com Feature-rich, frequently updated, ATI designed CATALYST software Graphics controller RADEON 9500 Visual Processing Unit (VPU). 275 MHz engine clock Memory configuration 128MB of double data rate DDR SDRAM - 540 MHz memory speed Operating system support: Windows® XP, Windows® 2000, Windows® Me. Display support VGA connector for analog CRT S-video or composite connector for TV/VCR DVI-I connector for digital CRT or flat panel Independent resolutions and refresh rates for any two connected displays FeaturesEight parallel rendering pipelines Four parallel geometry engines 128-bit DDR memory interface AGP 8X support SMARTSHADER 2.0 Programmable pixel and vertex shaders 16 textures per pass Pixel shaders up to 160 instructions with 128-bit floating point precision Vertex shaders up to 1024 instructions with flow control Multiple render target support Shadow volume rendering acceleration High precision 10-bit per channel frame buffer support Supports Microsoft® DirectX® 9.0 and the latest version of OpenGL® SMOOTHVISION 2.0 2x/4x/6x full scene anti-aliasing modes Adaptive algorithm with programmable sample patterns 2x/4x/8x/16x anisotropic filtering modes Adaptive algorithm with bi-linear (performance) and tri-linear (quality) options HYPER Z III 3-level Hierarchical Z-Buffer with early Z test Lossless Z-Buffer compression (up to 24:1) Fast Z-Buffer Clear TRUFORM 2.0 2nd generation N-Patch higher order surface support Discrete and continuous tessellation levels per polygon Displacement mapping VIDEOSHADER Seamless integration of pixel shaders with video FULLSTREAMvideo de-blocking technology Noise removal filtering for captured video MPEG-2 decoding with motion compensation, iDCT and color space conversion All-format DTV/HDTV decoding YPrPb component output Adaptive de-interlacing and frame rate conversion Dual integrated display controllers Dual integrated 10-bit per channel 400 MHz DACs Integrated 165 MHz TMDS transmitter (DVI 1.0 compliant) Integrated TV Output support up to 1024x768 resolution Optimized for Pentium® 4 SSE2 and AMD Athlon 3Dnow! PC 2002 compliant Warranty 1 year. 2D display modes Resolutions, colors and maximum refresh rates (Hz) in 256, 65K or 16.7M colors: Monitor Resolution, Hz: 640x480, 120 800x600, 120 1024x768, 120 1152x864, 120 1280x1024, 120 1600x1200, 85 1920x1080, 75 1920x1200, 75 1920x1440, 75 2048x1536, 60 Maximum 3D resolutions: 65K colors 2048x1536, 16.7M colors 2048x1536.
פורסם 2004 במרץ 622 שנים מחבר לא יצא טוב קיצור כתוב שם נראה לי שזה עם 4 pipelines ואמור להיות 8 בגרסת הפרו לא??תסתכלו על המודגש בכתום זה קצת מבולבל ה-4 לא מחובר למיליםתודה מראש
פורסם 2004 במרץ 622 שנים כמו שכתוב 275/540 כלומר PROעריכה: לפי טום זה פרו:http://www20.tomshardware.com/graphic/20031229/index.htmlבמבט שני לPRO ולNP יש אותם מהירויות שעון רק שבPRO יש 8 צינורות עיבוד לעומת הNP שהוא עם 4כלומר אחרי כל העריכות האלה..........NP
פורסם 2004 במרץ 622 שנים מחבר טוב אז עובדים פה בעינייםאגב אור שאלה פרטית בשביל אתה מרוצה מהכרטיס מסך שלך אם אני לא טועה זה 9600pro ?ויש מקרים בהם 9600 פרו עוקף את 9500 פרו בביצועים ?סתם שאלה בשביל הידע תודה מראש
