פורסם 2004 בפברואר 1922 שנים +===========================================+=============+====+=============+ | Description | Source |Pin | Acronym | +-------------------------------------------+-------------+----+-------------+ | Reset | Host | 1 | RESET- | | | n/a | 2 | Ground | | Data bus bit 7 | Host/Device | 3 | DD7 | | Data bus bit 8 | Host/Device | 4 | DD8 | | Data bus bit 6 | Host/Device | 5 | DD6 | | Data bus bit 9 | Host/Device | 6 | DD9 | | Data bus bit 5 | Host/Device | 7 | DD5 | | Data bus bit 10 | Host/Device | 8 | DD10 | | Data bus bit 4 | Host/Device | 9 | DD4 | | Data bus bit 11 | Host/Device | 10 | DD11 | | Data bus bit 3 | Host/Device | 11 | DD3 | | Data bus bit 12 | Host/Device | 12 | DD12 | | Data bus bit 2 | Host/Device | 13 | DD2 | | Data bus bit 13 | Host/Device | 14 | DD13 | | Data bus bit 1 | Host/Device | 15 | DD1 | | Data bus bit 14 | Host/Device | 16 | DD14 | | Data bus bit 0 | Host/Device | 17 | DD0 | | Data bus bit 15 | Host/Device | 18 | DD15 | | Ground | n/a | 19 | Ground | | (keypin) | n/a | 20 | Reserved | | DMA Request | Device | 21 | DMARQ | | Ground | n/a | 22 | Ground | | I/O Write | Host | 23 | DIOW- | | Ground | n/a | 24 | Ground | | I/O Read | Host | 25 | DIOR- | | Ground | n/a | 26 | Ground | | I/O Ready | Device | 27 | IORDY | | Spindle Sync or Cable Select | (note 1) | 28 | SPSYNC:CSEL | | DMA Acknowledge | Host | 29 | DMACK- | | Ground | n/a | 30 | Ground | | Interrupt Request | Device | 31 | INTRQ | | 16 Bit I/O | Device | 32 | IOCS16- | | Device Address Bit 1 | Host | 33 | DA1 | | PASSED DIAGNOSTICS | (note 1) | 34 | PDIAG- | | Device Address Bit 0 | Host | 35 | DAO | | Device Address Bit 2 | Host | 36 | DA2 | | Chip Select 0 | Host | 37 | CS0- | | Chip Select 1 | Host | 38 | CS1- | | Device Active or Slave (Device 1) Present | (note 1) | 39 | DASP- | | Ground | n/a | 40 | Ground | +-------------------------------------------+-------------+----+-------------+
