Mac air 13" and Logitech Z906
Please someone can help?
I don't understand how to connect the cables
I tried with the green one but sound is shit
thanks in adavnce for your help
Hello and welcome to the forum.
The laptop's sound card is of a low quality compared to a high quality sound card.
You need a DAC (Digital to Analog Converter) to improve the sound of the speakers connected to the laptop.
Ivory is selling the Audioquest Dragonfly for 690 NIS which is a great price for this particular DAC if you can afford it.
http://www.ivory.co.il/catalog.php?id=9644
It should really improve the sound quality on any laptop or computer.
שומעים אצלו "לא טוב" כי הוא מחבר מערכת של 5.1 בחיבור סטיראו , לא כי כרטיס הקול המובנה זבל .. הוא צריך כרטיס קול חיצוני עם שתומך ב5.1 האודיו(שלוש כבלי סטיראו..) ,לחלופין כרטיס קול בUSB עם יציאה אופטית דיגטלית ..
hey, thanks, many thanks , first of all
so I have two options as far as I understood
the first one is a dac
the second is an external sound card with usb that support 5.1
what about this ?
it will solve my problem ?
http://us.store.creative.com/Sound-Blaster-XFi-Surround-5.1/M/B0017QQQAE.htm
or this one that apparently it seems to be the improved model
http://www.soundblaster.com/products/Sound-Blaster-X-Fi-HD.aspx
I think z906 has dts and also thx so i would like to take advantage of these 2 technologies and buy something that will allow me to do so
thanks thanks thanks for the help
- - - תגובה אוחדה: - - -
what about this ?
Splashy, thanks a lot!
Apparently it is not possibile to find it in Israel ......zap............
in any case can you suggest which optical cable to buy ? i think on z906 there are 2 optical inputs
probably a stupid question , but with the z906 i got cables of 3 different colors , to connect the subwoofer with my future external usb sound card ,why they are worse then an optical cable, sorry for the ignorance
thanks
there are maybe some other options ? cause i will be in europe only in october and would like to test asap the speakers.
six
KSP has a USB soundcard that might suit your needs:
http://ksp.co.il/?uin=19257
hey, thanks again.
after 2 hours reading reviews on the web I decided for
I will try to find it here in Israel
if is not gonna be possibile I will wait until end of september and buy it in europe for less than 300 shekel
thanks again
six
hey, thanks again.
thanks again
six
hey everybody
at the end I purchased the Sound Blaster x-fi surround 5.1 pro and also an optical cable of tomslink
I finally got all the speakers of the z906 ringing
but.......
cannot find a control panel for the z906 neighter for the sound blaster
and also apparently the usb cable ( mac book air connected to sound blaster ) operates at a speed of 1.1.
this can effect the quality of the sound ?
please someonne has some tips in order to how to get the maximum from these spekears with this macbook air ?
thanks
frankly speaking i dont feel the sound ( power and quality ) to be particularly impressive.
העברתי את הדיון לפורום אודיו המתמחה ברמקולים וכל מה שקשור לאודיו. בהצלחה.
thanks a lot.
hey everybody
לא הבנתי לאיזה לוח בקרה אתה מתכוון
בקשר למהירות ה USB באתר של קריאייטיב רשום שהתקן הוא USB2.0 , זה אכן עלול להשפיע במידה מסויימת, תנסה לבדוק הגדרות ב UEFI
הכבל USB שאתה משתמש בו הגיע עם הכרטיס קול ?
נערך על-ידי avilavi
