מפרט לשימושים משרדיים בעיקר, ריבוי מסכים +אוברקלוק מזערי
[TABLE=class: productListing, width: 100%]
[TR]
[TD=class: productListing-heading, align: center]Remove[/TD]
[TD=class: productListing-heading]Product(s)[/TD]
[TD=class: productListing-heading, align: center]Quantity.[/TD]
[TD=class: productListing-heading, align: right]Total[/TD]
[/TR]
[TR=class: productListing-even]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzZztqdkdnd3g..&w=16&h=22&f=jpg&q=95&hash=10d9c14da1a34d113735a2d7056ca8ba[/TD]
[TD=class: productListing-data][TABLE]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzA0-DRz562rJKgopqfuJe13tvG1ODq1N6azd_U&w=30&h=22.5&f=jpg&q=95&hash=06d21413925971b7ebd0583c2fe978f0[/TD]
[TD=class: productListing-data]Intel Core I5-4670K Processor Box [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: center][/TD]
[TD=class: productListing-data, align: right]₪1,149[/TD]
[/TR]
[TR=class: productListing-odd]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4py-ztPNxejh3JSknJeozOST1tzK&w=30&h=22.0434782609&f=png&q=95&hash=d1f54ca309a3313b71f1dc87b55f7567[/TD]
[TD=class: productListing-data]Gigabyte Mainboard GA-H87-HD3 LGA 1150 [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪537[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4py61N7fxNjfppufnpynzOOT1tzK&w=30&h=15&f=jpg&q=95&hash=9edcf15e45ebcaacf9df95e9a8858b1c[/TD]
[TD=class: productListing-data]Memory Corsair DDR3 8Gb Kit XMS3 [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪377[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzDrJvcwqGeqprLzszWm-HV0w..&w=30&h=29.8360655738&f=jpg&q=95&hash=07c9d27bc2d1320c27769ad8be9f857c[/TD]
[TD=class: productListing-data]DVD-RW LG GH22NS70 x22 [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪110[/TD]
[/TR]
[/TABLE]
Sub-Total: ₪2,173
בקשר לספק אני מתלבט אם לקחת אחד פשוט ב-120, כדוגמת זה או להשקיע.
יש לי ספק ישן של אנרמקס שאני מאוד מרוצה מפיצ'ר ספציפי שיש לו, בקרה של נפילת מתח רגעית בבית המחשב שלי הוא הדבר היחיד שלא כבה. תמליצו על ספק בבקשה.
כונן קשיח יש, מארז יש (ספק עילאי).
כרגע אני לא מתכנן אוברקלוק (בעתיד כן), לכן אין צורך בקירור שונה למעבד.
ועוד משהו שמאוד חשוב לי זה שהלוח יתמוך בשלושה מסכים בו-זמנית, על המעבד אני יודע שהוא כן תומך.
וסליחה אם ההודעה לא מנוסחת כמו שצריך
4670 הוא אוברקיל מופרז עבור שימושים משרדיים. עבור שימושים כאלה אין צורך במעבד יקר כ"כ
כל מעבד, גם הכפול הזול ביותר יהיה חזק מספיק לשימושים משרדיים. אתה אפילו לא תרגיש הבדל...
כן, אולי נשחק קצת במשחקים, פרו וכאלו. הבנתי שיש בו שבב גרפי טוב.
וגם, אני מעוניין באוברקלוק קטן בעתיד ורק בסדרה K יש אפשרות.
ההתלבטות שלי זה עם הספק, ובקשר לזיכרון אני לא כל כך בטוח.
לשם מה אתה צריך OC?
סתם לכיף, לא משהו מטורף
הכיף הזה יעלה לך לא מעט כסף.
אז מה אתה מציע?
לקחת סתם מעבד חלש?
אם אקח i5 הוא יחזיק לי יותר שנים כמחשב שאפשרר לתפקד איתו.
למשל, המחשב שלי התחיל כמחשב משחקים חזק והוא שרד 8 שנים והיום הוא קצת מקרטע (כמשרדי).
אתה יכול לקחת מעבד זול ולשדרג \ להחליף עוד 3-4 שנים.
אם השימושים לא ישתנו, אין סיבה שהמחשב יהפוך פתאום לפחות טוב.
זה לא שהוא יהפוך לפחות טוב זה שהדרישות מהשימושים היום יומיים יעלו, כמו שקורה תמיד.
בכל אופן אני לא רואה טעם בלשדרג (מעבד), עדיף להחליף הכל.
מה בקשר לזיכרון, הוא יתאים למערכת הזו?
ועל איזה ספק תוכל להמליץ?
תודה על התגובות :xyxthumbs:
הזיכרון יתאים אך שים לב שניתן למצוא 8GB בכ-100 ש"ח פחות.
אם בכל זאת תרצה לבצע OC, שים לב שעם הלוח הנ"ל לא תוכל.
ספק - s12II של סיסוניק. 430W יהיו מעל ומעבר.
הערה חשובה מאוד
תוכל להמיץ לי על לוח מאותה סדרה של גיגהביט שכן יאפשר
נערך על-ידי adlanm
אז בגלל שהלוחות עם Z87 יקרים ומעלים את המחיר בהרבה הורדתי את המעבד K
וזה מה שיצא
[TABLE=width: 100%]
[TR]
[TD][TABLE]
[TR]
[TD][TABLE]
[TR]
[TD=class: mws_boxCenter][TABLE=class: productListing, width: 100%]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzA0-DRz562rZ6ZoJmmndbb2c3M3Z2oxNHQxs7a5cSknJamnauZmtbT1g..&w=30&h=30&f=jpg&q=95&hash=f76d21094c4bbd1a883ac18b03ff884c[/TD]
[TD=class: productListing-data]Intel Core I5-4670 Processor Box [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪1,058[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD=class: productListing-data, align: center]oscthumb.php?src=nODSzdPI4pzA09LV0djh8JSlnZCgm-HV0w..&w=30&h=16.6666666667&f=jpg&q=95&hash=642b361e70ba28c3bbfffced74d02e00[/TD]
[TD=class: productListing-data]Infinity 450W 120mm, 4*Sata , Fan speed control [/TD]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: productListing-data, align: right]₪121[/TD]
[/TR]
[TR]
[/TD]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=class: mws_boxRight][/TD]
[/TR]
[TR]
[TD]lower_left.gif[/TD]
[TD=class: mws_boxBottom][/TD]
[TD]lower_right.gif[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]pixel_trans.gif[/TD]
[/TR]
[TR]
[TD=class: main, align: right]Sub-Total: ₪2,203[/TD]
[/TR]
[/TABLE]
בקשר לזיכרון לא מצאתי 8GB Dual Channel יותר זול משמעותית, תוכל לכוון אותי.
כל שני סטיקים של 4GB יתנו לך dual channel (וזה גם ככה לא כ"כ משנה).
הספק שבחרת ג'נרי.
ספק ג'נרי זה לא טוב?
צריך להשקיע בסביבות ה-200-250 בספק?
