הוספת 2X4GB זכרון ל- 2X2GB הקיימים, וינ 7 64 ultimate
שלום לכולם.
החלטתי להוסיף זכרון למחשב שלי.
הפרטים המלאים של המחשב שלי:
Summary
Computer Brand Name: GIGABYTE P55A-UD4P
Operating System: Microsoft Windows 7 Ultimate (x64) Build 7601
Service Pack: Service Pack 1
Processor: Intel Core i5-750 (2666.7 MHz)
Motherboard: GIGABYTE P55A-UD4P (Intel P55 (IbexPeak))
Memory: 4 GBytes (Dual-Channel)
Hard Drive: Seagate ST2000DM001-9YN164 (1,907,725 MBytes (2000 GB))
Optical Drive: HL-DT-ST DVD-RAM GSA-H55N (DVD+R DL)
Marvell 91xx Config (Processor)
Display Adapter: ASUS EAH5850
Audio Adapter: Intel 5 Series/34x0 Chipset PCH - High Definition Audio Controller [B3]
ATI/AMD Cypress - High Definition Audio Controller
Network Adapter: RealTek Semiconductor RTL8168D/8111D PCI-E Gigabit Ethernet Adapter
Monitor: DELL [Unknown Model: DELF017]
SAMSUNG [Unknown Model: SAM083E]
Processor
CPU ID: 000106E5
Code Name: Lynnfield
CPU Stepping: B1
CPU Platform: Socket H1 (LGA1156)
Microcode Update Revision: 4
Core(s): 4
Thread(s): 4
Original Frequency: 2666.7 MHz
Current Frequency: 2797.6 MHz = 21.00 x 133.2 MHz
CPU Core Temperature: N/A
L1 Cache: Instruction: 4 x 32 KBytes, Data: 4 x 32 KBytes
L2 Cache: Integrated: 4 x 256 KBytes
L3 Cache: 8 MBytes
CPU Thermal Design Power: 95.0 W
CPU Thermal Design Current: 89.0 A
Motherboard
Model: GIGABYTE P55A-UD4P
Chipset: Intel P55 (IbexPeak)
Slots: 2xPCI, 5xPCI Express x1, 2xPCI Express x8
PCI Express Version Supported: v2.0
USB Version Supported: v3.0
Super IO/LPC Chip: ITE IT8720F + SMSC 37N972
BIOS Manufacturer: Award Modular BIOS v6.00PG
BIOS Date: 12/03/09
BIOS Version: F6
Memory
Module Number: 0
Module Size: 2048 MBytes
Module Type: Unbuffered DIMM (UDIMM)
Memory Type: DDR3 SDRAM
Memory Speed: 666.7 MHz (PC3-10600)
Module Manufacturer: G Skill
Module Part Number: F3-10666CL9-2GBNQ
Module Revision: 0
Module Serial Number: 0
Module Manufacturing Date: Year: 2000, Week: 0
SDRAM Manufacturer: G Skill
Error Check/Correction: None
Number Of Banks: 8
Number Of Ranks: 2
Device Width: 8 bits
Bus Width: 64 bits
Module Density: 1024 Mb
Module Voltage: 1.5 V
Minimum SDRAM Cycle Time: 1.500 ns
CAS# Latencies Supported: 6, 7, 8, 9
Minimum CAS# Latency Time: 13.500 ns
Minimum RAS# to CAS# Delay: 13.500 ns
Minimum Row Precharge Time: 13.500 ns
Minimum Active to Precharge Time: 36.000 ns
Minimum Write Recovery Time: 15.000 ns
Minimum Row Active to Row Active Delay: 6.000 ns
Minimum Active to Active/Refresh Time: 49.500 ns
Minimum Refresh Recovery Time Delay: 110.000 ns
Minimum Internal Write to Read Command Delay: 7.500 ns
Minimum Internal Read to Precharge Command Delay: 7.500 ns
Minimum Four Activate Window Delay Time: 30.000 ns
Supported Module Timing at 666.7 MHz: 9-9-9-24
Supported Module Timing at 400.0 MHz: 6-6-6-15
Auto Self Refresh: Not Supported
Extended Temperature Range: Supported
Extended Temperature Refresh Rate: Not Supported
On-die Thermal Sensor Readout: Not Supported
Module Number: 2
Module Revision: 0
Number Of Banks: 8
Number Of Ranks: 2
Bus Width: 64 bits
Hard Drive
Drive Model: Seagate ST2000DM001-9YN164
Drive Controller: Serial ATA 6Gb/s
Drive Serial Number: W1E0ERMP
Firmware Revision: CC4C
Drive Capacity: 1,907,725 MBytes (2000 GB)
Media Rotation Rate: 7200 RPM
Temperature: N/A
Cache Buffer Size: N/A
Number of Cylinders: 16383
Number of Heads: 16
Number of Sectors: Unknown
Sectors Per Track: 63
Native Command Queuing: Supported, Max. Depth: 32
TRIM Command: Not Supported
Write Cache: Present, Active
S.M.A.R.T. Feature: Present, Active
Security Feature: Present, Inactive
Removable Media Feature: Not Present, Disabled
Power Management: Present, Active
Advanced Power Management: Present, Active
Packet Interface: Not Present, Disabled
Look-Ahead Buffer: Present, Active
Host Protected Area: Present, Enabled
Power-Up In Standby: Not Supported, Inactive
Automatic Acoustic Management: Not Supported, Inactive
48-bit LBA: Supported, Active
Raw Read Error Rate: 115/6, Worst: 99 (Data = 87165080)
Reallocated Sector Count: 100/36, Worst: 100
Power-On Hours/Cycle Count: 93/Always OK, Worst: 93 (Data = 6659)
Power Cycle Count: 100/20, Worst: 100 (Data = 74)
SATA Interface Downshift / Runtime Bad Block: 100/Always OK, Worst: 100
Reported Uncorrectable Errors: 100/Always OK, Worst: 100
Command Timeout: 100/Always OK, Worst: 99 (Data = 1)
Spin Up Time: 95/Always OK, Worst: 95
Start/Stop Count: 100/20, Worst: 100 (Data = 68)
Seek Error Rate: 72/30, Worst: 60 (Data = 151418104)
Spin Retry Count: 100/97, Worst: 100
Temperature: 32/Always OK, Worst: 41 (Data = 32.0 C)
Power-Off Retract Count: 100/Always OK, Worst: 100 (Data = 67)
Load/Unload Cycle Count: 100/Always OK, Worst: 100 (Data = 512)
Current Pending Sector Count: 100/Always OK, Worst: 100
Off-Line Uncorrectable Sector Count: 100/Always OK, Worst: 100
Ultra DMA/SATA CRC Error Rate: 200/Always OK, Worst: 200
Optical Drive
Drive Model: HL-DT-ST DVD-RAM GSA-H55N
Device Type: DVD+R DL
Drive Serial Number: 39745C02
Firmware Revision: 1.00
Supported Disk Type (Read): CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Supported Disk Type (Write): CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM, DVD+R DL
Drive Model: Marvell 91xx Config
Device Type: Processor
Firmware Revision: 1.01
Display Adapter
Video Card: ASUS EAH5850
Video Chipset: ATI/AMD Radeon HD 5850 (CYPRESS PRO)
Video Memory: 1024 MBytes of GDDR5 SDRAM
Bus Type: PCIe v2.0 x16 (5.0 Gb/s) @ x2 (5.0 Gb/s)
Video BIOS Version: 012.020.000.005.035153
Memory Bus Width: 256-bit
Number Of Pixel Pipelines: 32
Number Of Unified Shaders: 1440
GPU Temperature: N/A
Memory Clock: 1000.0 MHz (Effective 4000.0 MHz)
Audio Adapter
High Definition Audio Codec: RealTek ALC889
Audio Adapter: ATI/AMD Cypress - High Definition Audio Controller
High Definition Audio Codec: ATi RADEON HDMI
Network Adapter
MAC Address: 6C-F0-49-54-EF-41
Maximum Link Speed: 1000 Mbps
Monitor
Monitor Name: DELL [Unknown Model: DELF017]
Serial Number: F525M04E0Y1L
Date Of Manufacture: Week: 16, Year: 2010
Max Vertical Size: 32 cm
Max Horizontal Size: 52 cm
Suspend: Not Supported
Standard Colour Space: Not Supported
Preferred Timing Mode: Supported
Default GTF Supported: Not Supported
Monitor Name: SAMSUNG [Unknown Model: SAM083E]
Serial Number: H9LB600011
Date Of Manufacture: Week: 25, Year: 2011
Max Vertical Size: 23 cm
Max Horizontal Size: 41 cm
Time of this report: 17/4/2013 18:15:02
HWiNFO32.dll: 3.9.6.0
HWiNFO32.sys: 8.72.0.0
HWiNFO64A.sys: 8.72.0.0
המצב הקיים שבו רצות התוכנות/דפדפן וכו' השימוש בזיכרון שלי נע בין 60%-70% ודי מהר אני מגיע לסף כאשר אני מפעיל עוד כמה דברים במקביל...
חשבתי להוסיף את הזכרונות האלו
http://ksp.co.il/?uin=12377
גם המחיר מתאים וגם לדעתי הנפח הכולל הוא אידיאלי, לשימושים שהמשחב הזה יוכל להריץ.
דעתכם? המלצה על זכרון יותר טוב/מומלץ באותו מחיר ונפח?
אשמח להתייחסותכם,
תודה.
קנה עוד סטיק של 4GB, בשביל מה יותר?
למה לקנות זיכרונות כאלו יקרים? קנה את זה:
http://ksp.co.il/?uin=10232
אין חובה שיהיו שני כרטיסים במקביל ? duel?
לדעתך 8 יספיקו? לא עדיף 12?
והאמת החברה הזאת לא ממש מוכרת לי לפחות(לא שאני בקיא גדול בכל העניין הזה), היא חברה איכותית?
תודה.
אין חובה, אבל עדיף.
ראה תגובתי למעלה.
בקשר לחברה - הכל טוב :)
אם עדיף, ומכיוון שאין לי בעיה להוציא את הסכום הנדרש אז אני אלך על שני סטיקים.
בעצם אז אני אצטרך לקנות 2 סטיקים של הזכרון שהוצע לי, אבל הוא לא נמצא בסניף בפ"ת ובאייבורי בכלל לא מוכרים את החברה הזאת.
ההבדל בין שניים כאלה למה שחשבתי לקנות בהתחלה מסתכם ב 50 שקלים שמבחינתי לא מפריע לי.
במידה ולדעתכם אמרתי דברי הגיון אשמח אם תגידו, ואז אני אקנה את הזכרונות האלה.
תודה על העזרה.
אם כוונתך לקנות שני סטיקים כמו מה שהציע אור בגלל
שאלה שאתה כתבת לא נמצאים בחנות - סבבה.
:xyxthumbs:
אה, לא הבנת חח, יכול להיות שאני לא הסברתי את עצמי טוב, הסטיקים שאור הציע לא נמצאים מה שאני כתבתי כן נמצאים.
אוקי, תודה רבה לכם על העזרה, מודה מקרב לב :yelclap:
