מזה AGP SIZE משהו...
שלום לכולם
רציתי להבין פעם אחת ולתמיד מזה AGP SIZE זה נמצא בביוס ויש כמה אפשרויות מ 32M עד 512M ועל כמה להשים את זה ??
First of all, AGP Aperture memory will not be used until your video card's on-board memory is running low. That means it will usually not impact your gaming performance because developers are trying hard to not exceed the on-board memory limits.
The bigger your video memory, the smaller your Aperture Size could be. However with later games requiring more and more texture memory a good number seems to be 128MB Aperture Size for all cards with 64 MB to 256 MB Video RAM.
Setting the Aperture Size to HUGE values will not increase performance because this merely sets the maximum amount of physical memory that can be used. It only makes the GART Table bigger because every 4K page has its own entry, no matter if allocated or not.
Setting the Aperture Size to too small values could result in running out of available texture memory especially on a low-mem video card.
אם כבר כתבת באנגלית, לפחות תיישר משמאל!
עשיתי copy paste אם אין לך מה להגיד אז אל תעביר הודעת spam
x-dude... would you just answer his question: "What is AGP Aparture Size" ?
The AGP Aparture Size value is how much memory you allow the graphic card to use when it runs low on it's own memory. Setting it to 128MB should be plainly enough.
huh? אתה עיור? עניתי לו בפירוט
ההסבר של Xdude היה מעולה!
ההסבר של Psychopath היה מיותר.
x-dude simpley dind't mention what the AGP Aparture size IS ! not what settings it's suypposed to be
