עוד שיא חדש ל-AMD
I find that more impressive personally.
And Indeed, if people didn't care more about high numbers (for example the latest Tomshardware P4 o/c project) I think overclocking should only count if it's a stable configuration capable of working constantly over long periods of time.
Unlike a configuration that needs Liquid Nitrogen to poured into it constantly which is possibly the least practical thing I can think of.
  • תגובות 33
  • צפיות 2.4k
I partially agree with you at that, but the PC world can be parallelly compared to the street racing world.
Just take NOS as a replacement no liquid nitrogen and modify your question:
"Unlike a car that needs NOS to be poured into it constantly which is possibly the least practical thing I can think of." Right?
But people do it for some reason, psychologically to boost their ego or whatever and personally because it gives that feeling of self-satisfaction, like: "My old crappy PC can run at that speed, even if it's for a short period of time and with many inconveniences".
IMHO ;)
I concur, it certainly has something to do with boasting your ego.
Regardless, very impressive results, can you reach these speeds with a higher FSB aswell?
תוצאות יפות מאד! :D
ה 200x12.5 יציב 100%?
באיזה קירור אתה משתמש?
214 זה הבאס הגבוה ביותר שאתה יכול? די חבל, המעבד נראה מצויין, היית עושה באס גבוה מאד בקלות.
ד"א דירוג מלא של המעבד?
No, not really, for one of the 2 reasons:
1. Crappy motherboard, if I could get one that has adjustable VNorthBridge, then maybe.
2. PC2700 (166mhz) ram... it's good enough that it reaches 214mhz imo ::)
תוצאות יפות מאד! :D
12.5x200 יציב 100% ב1.9V, קירור Vantec Aeroflow, קוד מלא: KIUHB DUT3C :)
I have an 1700+ with the exact same stepping, which week is yours?
I also managed to do 2400 mhz at 1.9V but I didn't have appropriate cooling to handle it, and I also did 2200 at 1.65V.
אני כל הזמן שוכח מאיזה שבוע הוא, אבל נראה לי שזה שבוע 22 של '03. אם קנית אותו כמוני במכירת החיסול של פנדה ב-299 ש"ח אז יש לנו אותו שבוע ;)
Naa, I bought it in PCH, around the same time though.
I can't recall which week is mine but I will check tomorrow
אני ב-1.9 מסוגל להעלות וינדואס עד 2450 מה"צ, למען האמת, יותר מ- 1.9, אני די מפחד לתת, אפילו באופן חד פעמי.
כל עוד הטמפרטורה בסדר אין בעיה לתת מתח גבוהה.. לפחות לא לאורך זמן
לא מדוייק... ככל שהטמפרטורה נמוכה יותר ככה המעבד נשחק לאט יותר, אבל הוא עדיין נשחק ויחסית מהר באוברקלוקים כאלה... ::)
אם רק היה לי קירור על רמה במקום הסטוק- כולכם הייתם מקבלים בראש עם איזה 2700-2800 מגה הרץ!
זה לא צחוק אני בטוח שהוא טוב!
לא מפחד, אבל חבל סתם להגזים, ואז לגלות לפני שוינדואס עולה את אותו הריח השרוף והמבשר רעות.
I'm wondering whether this result got added to the OC Database, I added it like 2 or 3 days ago and it's still not there...
:cwm24:
