מחשב למשחקים ואולי ל-OC
חבר שלי רוצה לקנות מחשב בתקציב של עד 6500ש"ח
הוא בנה לבדו מפרט והוא רוצה חוות דעת עליו
תודה מראש
Intel Pentium IV 2.8C GHz HT 512K 800MHz Socket 478 CPU BOX [1290.0]
ABIT IC7-MAX 3 Intel 875P Motherboard (HT,OTES,Dual SATA RAID,D-DDR,5.1 Sound,Intel G-LAN,1394,USB2) [1,267.89]
CORSAIR DDR-RAM 256MB 3200 Low Latency CAS2 Memory (x2) 1551.50]
Albatron Geforce FX 5900XTV 128MB DDR DVI VIVO Retail Video Card [1227.0]
Western Digital 120GB 7200 rpm 8MB Buffer Serial ATA HDD [661.0]
Thermaltake Spark 7+ Highest Performance CPU Cooler for PIV-478 [159.65]
Simbadda Master I LU Midi Tower Case Silver 480 Watt [276.0]
Teac 52/24/52 Bulk CDRW [268.43]
Subtotal NIS 6,304.49
אם יש למישהו הצעות לשיפור או מפרט שונה להציע
אני אשמח לשמוע
(כל המחירים הם מPCH)
Most of the components are good but the case is just horrible and it also has a generic PSU.
Take atleast a Compucase case with a HEC 300W psu though if you want better cooling you could get a Supertalent Aluminum case (comes with 5 fans) for around 580 nis.
If you want to seriously overclock you better take RAM which is better for overclocking, I suggest you take OCZ PC3500 Platinum series.
The IC7-Max3 has some problems with VDIMM of above 2.8V. I know Abit released fixed boards abroad but I'm not sure if the boards currently available in Israel aren't older and defected. I suggest you take the Asus P4C800 instead, it should cost slightly less and it's a superb board. Another option is the cheaper Asus P4P800 or the Epox 4PDA2+.
If you wait a little the price of the 2.8C is supposed to go down in about two weeks.
