בעיה בהתקנת פאץ' למשחק
שלום!
אני מנסה להתקין פאץ' רישיונות לPES 2013 אבל תמיד שאני לוחץ INSTALL מופיע לי ריבוע באמצע המסך שבו רשום:
unhandled exception has occurred in a component in your application if you click continue
ויש גם דליס ושאני לוחץ על זה מופיע לי:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\Program Files\KONAMI\Pro Evolution Soccer 2013\img\dt04.img' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode)
at PeSBoX_2013_Demo_All_Teams_Patch_Installer.Setup.repackimg(String whichpes2013img, String whichsetupimg, String outputimgname)
at PeSBoX_2013_Demo_All_Teams_Patch_Installer.Setup.ButtonX4_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnClick(EventArgs e)
at DevComponents.DotNetBar.ButtonX.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevComponents.DotNetBar.PopupItemControl.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.269 (RTMGDR.030319-2600)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
PeSBoX 2013 Demo All Teams Patch Installer
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Users/קבצי%20משתמש/Desktop/PeSBoX%20Anatolia%202013%20v.0.1%20Installer/PeSBoX%20Anatolia%202013%20v.0.1%20Installer.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 10.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.0.30319.269 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.0.30319.233 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Win32 Version: 4.0.30319.278 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.0.30319.282 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
DevComponents.DotNetBar2
Assembly Version: 8.8.0.0
Win32 Version: 8.8.0.0
CodeBase: file:///C:/Users/קבצי%20משתמש/Desktop/PeSBoX%20Anatolia%202013%20v.0.1%20Installer/DevComponents.DotNetBar2.DLL
Accessibility
Win32 Version: 4.0.30319.1 built by: RTMRel
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
איך אני יכול לסדר את זה בכדי להתקין את הפאץ'??
תסביר בבקשה מה אתה מנסה לעשות - כי אם אתה מנסה "לפרוץ" תוכנה - הדבר לא נידון בפרום שלנו.
כמו כן - ובלי קשר - נא ערוך ההודעה שתהיה יותר קריאה (שימו בפונט בגודל וכיוב')
http://hwzone.co.il/community/index.php?topic=524032.0
בהמשך במידה ומדובר בהתקנת טלאי לגיטימי יועבר לפורום תוכנה - בהצלחה,
גבריאל
ה stack trace call אומר לך בדיוק מה הבעיה.
חבל שסתם הדבקת אותו במקום לנסות לקרוא ולהבין מה כתוב שם, לפני הכל.
תראה שלמשתמש שאיתו רץ היישום יש הרשאות ברמת הACL ל:
multicore תודה אחי סידרתי את זה :) עובד לי!
