FSB Overclocking...
Okay, I have an Abit NF7 with two 256MB XMS CL2 PC3200 memory sticks...
My friend has an Epox 8RAD+ with one 512MB XMS CL2 PC3200 PRO memory stick...
I tried overclocking the FSB at my computer (AXP2500), when the multiplier is 10... I can't seem to get it right and my windows doens't work.. or i even have to CMOS reset..
yet my friend can easily overclock (well actually i did it for him) his memory, and so far he's at 10x220 (didn't try further).
Could it be the dual DDR that stops me? or is it something else? I want to reach 2300mhz with at least a bit overclocked FSB, because I want more performance out of my DDR.
I'm, positive my CPU can reach 2300mhz, because right now I run at 2300mhz, Vcore 1.9 and 39 degrees celcius.
תבדוק אם הבעיה נפתרת כשאתה מוציא סטיק אחד
תנסה להעלות מתח לזכרונות
אולי אצלך הורדת את התזמונים ואצל חבר שלך הם ברגיל?
Well, most amazingly.. up to 210mhz, i didn't have to raise the timings with his memory at all...
After a lot of trying and faling, i realised: i'm stable at 210mhz and 3-4-4-9 (which sucks)
oh and the voltage is 2.9 which is HIGH !
help me please, what can i do to lower the voltage and get to 220 x 11 :\
with decent timings...
Did you try both sticks one at a time? what was the results?
Maybe your MB dosent get up so high and then i will say its damaged or somthing.
try putting the Vdd voltage on 1.7 take the Vdimm down to 2.7 and put cpu interface enabled.
and if it dosent work maybe your barton is craped and cant go over the 210
