Need a certainty!
ניסיתי לערוך !! אבל כל פעם שאני בא לערוך זה עושה לי שגיאה באקספלורר משום מה ! :-\
אבל צודק התמונה גדולה אז אני אשים לינק במקומה
הנה עשיתי ריסט ועכשיו אני מצליח לערוך.. חח לפעמים המחשב משתגע קצת
הנה לינק נורמלי לתמונה :
http://members.lycos.co.uk/csboy4ever/new6.jpg
Money is an issue, the loss of money for the ALX will be 40 shekels, That's all i can spare :\
bumping the message and updating :D
Aight, so I got my new ALX800 with a nice led fan (coolermaster - 35cfm).
the temps are extremely low, when the recommended fan for such a heatsink is the delta 80cfm fan :D
I feel very pleased and recommend that cheap heatsink to anyone who is looking for a good solution for air basaed cooling.
I also bought a cathode but for some reason it only lights up one side.. so I guess i fucked it up ? :P
anyways, pics soon :D
I am happy to hear everything worked out good for you.
Just let us know the temp. would you?
Okay, after a whole day of normal use of my computer:
1800mhz (AXP2500): 31 idle / 33 work (1.65v)
2200mhz (AXP3200): 34 idle / 37 work (1.65v)
2300mhz: 39 idle / 43 work (1.9v)
I used a coolermaster led fan that gives 35cfm.
unfortunately, there's a big jump of voltage between the 2200mhz and the 2300mhz.. and i pay with a big difference of temperature
by the way, mobo temperatures veries between 17 to 25 degrees.
**all results with:
**Abit NF7
**AXP 2500+ (overclocked)
**2 x 256 pc3200 corsair CL2
**modded supertalent case (two fans front - air in | one fan back - air out | one fan door - air in | one fan top - air out)
**all results with:
**Abit NF7
Nice!
