Need a certainty!
Okay, here's my CPU status as we speak:
AMD Athlon, 2362MHz, 512KB (0% Load) @ 50°C (Fan @ 4272 RPM), Core @ 1.936V / Case @ 28°C
I'm a little afraid such a temperature / voltage could be lethal for the CPU :\
Should I be glad and leave it this way or downclock ?
When i just leave the CPU at 11x200mhz i don't have to raise voltages at all, and thus.. 31c-35c temperatures...
P.S.
Will cleaning the HSF and entire cooling system (all fans .. but still) from dust help lowering the temps?
כן, הייתי אומר ש 1.9V זה "קצת" גבוהה לכל מעבד שהוא ...
לא הייתי מעלה כל כך בשביל עוד 150MHZ ...
150?
make that 500...
Well maybe in those temps. you should consider seriously to change your CPU Cooling.
Your system temp. looks cool to me but the cpu is high as well as the cpu VCORE.
In my opinion you should take the voltage down a bit to 1.85 and try the max OC with it.
After if the temps. still stay high change the cpu cooling for somthing better and consider getting a home made cooling system.
לא הייתי נשאר בטמפ' כאלו כאשר במתח כזה. אני מסכים עם DSTORM, תוריד מתח ותראה לאן הוא לוקח אותך...
SMSM, 1.9V זה לא כ"כ גבוה אם הקירור עושה עבודה טובה.
ok, So here's the temperatures...
I have (RIGHT NOW): winamp playing, mirc, trillian (icq thingy), and steam (cpu killer) running..
board 25c
cpu 45c
when it's in idle it goes lower
when i play counter-strike or run CPU burn for an hour, it goes to 50
ow are those temps?
Right now I use the Vantec AerFlow, and my case aiflow is great.
so, if i change to an even better cooler (lets say some thermalright heatsink based cooling) i'll be ok ?
I'm really afraid of water cooling, i'm not the kinda person for it.. both low budget and "fashlot" kinda person...
Well the best solution for you is the volcano 12+ but if you got the cash you may also get a SLK-900 /W Sf2
עקרונית כל סינק מבית ט'רמלרייט יהווה שיפור ניכר.
הכל תלוי בתקציב שלך, אתה מוזמן לפנות לסטיקי לקבל קצת יותר פרטים על מה יותר טוב ואילו מאווררים מומלצים.
I'm narrowed down to twqo solutions:
1. My friend buys the Vantec AF from me, and I buy myself a Thermalright SLK700 /w 70mm TMD fan.
2. My friend buys the Vantec AF from me, and I buy myself a Thermalright ALX800 /w my Coolermaster 35CFM led fan.
I like the second option better because it means I'll have a led fan on the CPU.. which in most cases turns out most impressive :D
tell me what you think.
The ALX800 is much better.
Dont forget with all thermalright Heatsinks you have to purchase a fan as well i will suggest on the SF2 Made by Thermaltake
Like I said, I have a nice led fan to put on the ALX800, it's a cooler master blue led fan.. 35CFM and barely loud at all. very good i believe :D
Okay fellas, thanks for the help.. and once i get everything done (including the enw UV cathode i'll install, i'll show some pics here :D thanks everyone.)
לא חבל לשים על סינק כל כך טוב כמו ה-ALX מאוורר של 35cfm ?!
אם כל כך חשוב לך היופי של המאוורר של המעבד קח את ה sf2 w/cool mod יש לי אותו והוא ממש ממש יפה !
אני אחפש תמונה שלו ואני אכניס לך פה כדי שתראה.. הוא גם יהיה הרבה יותר יעיל מהcooler master
ואתה תקבל את השינויים שאתה רוצה
קודם כל -> תמחק את ההודעה עם התמונה -> תערוך את ההודעה שלך לפני ותשים לינק לתמונה.
אין צורך במאוורר חזק כמו ה SF2, ה ALX יעבוד מצויין גם עם מאוורר פחות חלש מהקולרמאסטר.
