פורסם 2012 באפריל 514 שנים בזמן האחרון המערכת עובדת בצורה לא יציבה עם נטייה להתקע. לעתים אני מקבל BSOD.ניסיתי לסרוק את קובצי ה- DUMP אבל לא הצלחתי להגיע משם למסקנה ברורה.[tt]On Thu 05/04/2012 08:40:58 GMT your computer crashedcrash dump file: C:\Windows\Minidump\040512-16458-01.dmpThis was probably caused by the following module: ntkrnlpa.exe (nt+0xDCE34) Bugcheck code: 0xC000021A (0xFFFFFFFFB4E84160, 0xFFFFFFFFC0000006, 0x7502D1BF, 0x18FF448)Error: STATUS_SYSTEM_PROCESS_TERMINATEDfile path: C:\Windows\system32\ntkrnlpa.exeproduct: Microsoft® Windows® Operating Systemcompany: Microsoft Corporationdescription: NT Kernel & SystemBug check description: This means that an error has occurred in a crucial user-mode subsystem.There is a possibility this problem was caused by a virus or other malware. The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time. On Thu 05/04/2012 08:40:58 GMT your computer crashedcrash dump file: C:\Windows\memory.dmpThis was probably caused by the following module: ntkrpamp.exe (nt!KeBugCheckEx+0x1E) Bugcheck code: 0xC000021A (0xFFFFFFFFB4E84160, 0xFFFFFFFFC0000006, 0x7502D1BF, 0x18FF448)Error: STATUS_SYSTEM_PROCESS_TERMINATEDBug check description: This means that an error has occurred in a crucial user-mode subsystem.There is a possibility this problem was caused by a virus or other malware. A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: ntkrpamp.exe . Google query: ntkrpamp.exe STATUS_SYSTEM_PROCESS_TERMINATED Conclusion 2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers: ntkrpamp.exe [/tt]מה לעשות הלאה?
פורסם 2012 באפריל 514 שנים תנסה לפעול לפי ההנחיות הבאות:http://support.microsoft.com/kb/156669בברכה,חגי חדד
פורסם 2012 באפריל 514 שנים מחבר תודה, כבר החלטתי שאני אלך על בטוח פרמטתי והתקנתי את הווינדוס מאפס.בינתיים נראה שהעניינים הסתדרו.
