איך מורידים את המסנג'ר הזה?
איך מורידים את המסנג'ר הזה?עשיתי לו UNINSTALL אבל הוא חוזר ועשיתי לו ב MSCONFIG וכל פעם הוא חוזר
אולי אפשר בSERVICES? מישהו אולי יודע?
Unhiding Add/Remove Items
This is VERY usefull in taking out those annoying programs that the install didn't allow you to select NOT to install. Messenger and MSN Explorer for example. In your c:\windows\inf is a file called sysoc.inf edit this file with Notepad. If you can't find that file... I suggest you show all files.
You should see lines that look something like this:
msmsgs=ocgen.dll,OcEntry,msmsgs.inf,hide,7
Isn't it interesting how that word hide is in there? Yep you guessed it. Hit CTRL + H to Replace. In the "Find what" box type hide and then hit the "Replace All" button. Save, exit and go check your add/remove programs. Nice huh? A very clean way to un-install crap you don't need.
