Project: Simpley Blue!
Ok, after putting a lot of thinking into what exactly I plan to do, I've come to distinctive desicions with this case - Supertalent (the one with 5 fans and a window):
- Paint all the inside parts which are currently metalic, in light blue.
- Drill an 80mm fan hole up on the top and add a nice grill i saw in pandas with a chick on it.
- Pain my logo "sexypwnz" on the top of the case when the 80mm fan is a part of the "p" in "sexypwnz"
Now, the idea is to have 3 blue led fans (which I already have), those fans will light up the entire blue surface inside...
I also plan to somehow get rid of all the HDD/floppy drive bays in order to miprove the airflow and make the case look nicer..
materials:
- a lot of blue paint for cars
- a lot of masking tape
- an 80mm fan image to drill the hole with
- "kos" drill
- my dad to see I do everything right... :D
- a lot of good will
why am i posting this? I wanted to ask you guys if i'm forgetting something.. the thing is, that case cost me money and i don't want anything to go wrong :>
salamat :D
humm
תשייף קודם את הצבע הקודם איפה שאתה עומר לצבוע.. זה יעשה תצביעה חלקה ויפה יותר
ובקשר למארז.. חבל שקנית עם חלון.. היית יכול לעשות משהוא הרבה יותר יפה
the grill with the chick is taking alot of the air, blocking it
take something else..
umm, she's not that bad... i'll upload a pic soon.. you'll see it barely takes any air.. i' actually afraid some one will stick his hand in the fan and break one of the blades
A finger won't break the fan blade iv'e had some bad experience but never broke a blade...... ;D
Ok, so I improvised a little.. changed a few plans.. but the outcome is amazing in my opinion...
here it is
תעשה משהו בקשר לשריטות על הגג..
נהדר אחי
indeed, I will do so once I buy my fan's grill... :>
את השריטות ניתן היה למנוע ע"י מסקנטייפ כמו שיעצנו לך בת'ראד הקודם :P
עם מה קדחת בסוף את הפתח למאוורר?
או. קיי נראה לי שלפחות אחד מאיתנו עוור צבעים ;D
יצא סבבה.
Yes I know the scratches look back
but they were made by my stupidy weeks before these pictures were taken...
I cut the hole with a jigsaw after all (well, my dad did)
I couldn't get a nice blue color so i picked this orange... for the record, it looks amazing in reality.. the orange glows nicely to the blue lights...
and thanks for the comments, keep them coming :>
אתה יודע שאפשר די בקלות לפרק את הגג ואת החלק התחתון?
פשוט קודחים את הניטים החוצה ומחליפים אותם בברגים
heh, yeah well, i worked on the entire case anyhow... the paint and all.. and the nits are nicer than screws....
זה לא בידיוק כחול אבל יצא יפה מאוד..
עוד דוגמה למוד פשוט ועשוי היטב :]
