בעיית חומרה מוזרה Compaq (HP) Presario C700
Hello,
My C700, about 4 years old, will not turn on unless I lift its right part (where the CD&HD are) in the air.
If you try powering on while its on the table the fan will go on for a few seconds and then stop, power led is on, WLAN led stays orange.
After "lift-starting" it, it will run as usual but every little tilt will cause the screen to go black and the computer to hang.
Checked memory, it's OK.
Checked all screws are tight.
HD&CD work fine.
Please help....
