WhoCrashed
התוכנה Who Crashed
מראה את ההודעה הבאה לאחר מסכים כחולים:
[לקרוא אני יודע, לאבין מה הבעיה - לא כל כך]
On Thu 5/12/2011 5:11:22 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\051211-26785-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7FD00)
Bugcheck code: 0x7F (0x8, 0x80050031, 0x6F8, 0xFFFFF800031B8406)
Error: UNEXPECTED_KERNEL_MODE_TRAP
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the Intel CPU generated a trap and the kernel failed to catch this trap.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x6A045)
file path: C:\Windows\system32\drivers\atikmdag.sys
product: ATI Radeon Family
company: ATI Technologies Inc.
description: ATI Radeon Kernel Mode Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, ATI Technologies Inc.).
Google query: atikmdag.sys ATI Technologies Inc. UNEXPECTED_KERNEL_MODE_TRAP
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
שלום,
עד כמה שאני הבנתי - כרטיס מסך אוח הדרייבר שלו
תתחיל מהקל יותר - הסרה מלאה של הדרייבר והתקנת מעודכן (כ. מסך של ATI לפי ה-LOG)
בהצלחה,
גבריאל
בנוסף אני ממליץ לנסות כמה גרסאות שונות של דרייברים
האמת שהתקלה קרתה גם לפני שבועיים, וגם היום, לאחר שעדכנתי לגרסה האחרונה של CCC
האם יש סיכוי שיש בעיה בכך שלוח האם שלי הוא בעל ערכת שבבים של Nvidia, וכרטיס המסך שלי הוא של AMD???
לא (או יותר נכון סביר מאוד שלא)
אישית אני עובד עם אותו SETUP ואין לי שום בעיה
תתקין את הדרייבר שיש על הדיסק וחשוב מאוד לא לעשות עידכון/שדרוג של דרייבר קיים, כלומר קודם כל להסיר את הדרייבר המותקן דרך לוח הבקרה, אפילו תעשה את זה ב- SAFE MODE ורק אז תעלה את המחשב במצב רגיל ותתקין את הדרייבר מהדיסק
תודה רבה על התשובה, לא היה לי מושג שצריך להסיר דרייבר קיים לפני שמעדכנים.
אבל שאלה:
כשאתה אומר להתקין את הדרייבר שיש על הדיסק - למה אתה מתכוון - לדרייבר של לוח האם? או לדרייבר של כרטיס המסך?
בנוסף - אני מבין שאתה מציע להיכנס ל Safe Mode ורק אז לבצע - דרך הוספה/הסרה - את הסרת הדרייבר.
אבל - האם לא עדיף להשתמש ב DriveSweeper?
אם אתה מכיר את התוכנה driver sweeper זה מצוין
והבנתה אותי נכון:
1. להכנס ל- SAFE MOD
2. להסיר את הדרייבר דרך add/remove
3. להריץ driver sweeper על מנת לנקות שאריות
4. להעלות את המחשב במצב רגיל
5. יכול להיות שהדרייבר העדכני לא עבד טוב בגלל שעשיתה עדכון אז תנסה עכשיו להתקין אותו
אם עוד פעם לא יעבוד טוב אז תחזור על סעיפים 1-4 ואז תתקין דרייבר של כרטיס מסך מהדיסק שקיבלתה
מעולה!!!
תודה רבה!!!!!
(הדרייבר מהדיסק זהה לדרייבר מהאתר, ואף ישן ממנו - אז למה שבכלל ארצה להתקין אותו? רק במידה וכל האפשרויות האחרות כשלו. אבל עדיין - מדוע? האם זה בגלל שהוא בוודאות יעבוד? אולי כי הוא נוסה כבר על ידי החברה?
זאת הסקרנות שגורמת לי לשאול)
ההמלצה בגדול זה פשוט לנסות גרסה אחרת של דרייבר ומכיון שיש לך גרסה אחרת בישג יד (על דיסק) אז אתה לא צריך לחפש יותר מידי
באותה מידה אתה יכול למצוא גרסה ישנה באינטרטנט, לא חייב להשתמש בדיסק
מודה לך מאוד על הכל!!!
