מסכך כחול כנראה בגלל הכרטיס מסך
שלום בזמן האחרון המחשב התחיל להתקע לי והתחילו להופיע מסכים כחולים בדקתי WHO CRASHED וזה מה שיצא
On Thu 05/05/2011 15:48:17 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\Mini050511-01.dmp
This was probably caused by the following module: nv4_disp.dll (nv4_disp+0x2446BE)
Bugcheck code: 0x1000008E (0xFFFFFFFFE0000001, 0xFFFFFFFFB8430925, 0xFFFFFFFFB2A68704, 0x0)
Error: KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
file path: C:\WINDOWS\system32\nv4_disp.dll
product: NVIDIA Compatible Windows 2000 Display driver, Version 270.61
company: NVIDIA Corporation
description: NVIDIA Compatible Windows 2000 Display driver, Version 270.61
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: nv4_disp.dll (NVIDIA Compatible Windows 2000 Display driver, Version 270.61 , NVIDIA Corporation).
Google query: nv4_disp.dll NVIDIA Corporation KERNEL_MODE_EXCEPTION_NOT_HANDLED_M
מה לעשות?
תנסה להתקין גרסה יותר ישנה של הדרייבר
