Buying Water Cooling System
I finally decided to buy a water cooling system since if i wanna over i gotte pump the rpm and that just lame havin to play with that every day....
So i came to you Hwzone looking for info and advice that will help me decide what water cooling system will i buy...
since as i see it i can pick Emp which u all will prolly recommand...
but ive read the review here over that system and it didnt sound so great...
so ofcuse i went to "some sites" and saw the Azetek aka WaterChill...
Searched For some review about it and all looked sweeet as pie...
havent found any other systems sellin on sites....
unless u can direct me to one....
Im not so sure i wanna buy the system in parts like pump from one place and water block from the other id perfer buy a complete system...
and thats where u guyz get in the picture...
Emp Vs WaterChill
Inserted into an XaserIII V2000A case...
I repeat if u know any other systems that i can buy... in here or through israeli shops that will order it...
please inform me...
Btw if u guyz know how my case look ull prolly figure out i got 2 hardisk cages on the front... and wanted to know if anyone knows how do i takem off... cant find screw... tho havent looked firmly...
i just formated my comp and i dont have office yet so i cant really write in hebrew nor line it to left....
And about the money.... dont really know... what i do know... below 2kNIS.....
thanks...
Slim
אחי אני הייתי ממליץ על DangerDan. ב-200 דולר (~250 עם משלוח) אתה יכול לקנות מערכת קטלנית. תוסיף עוד 100$ ואתה עם קירור חזק במיוחד לכל חלק שבא לך.
עדיף יותר (אני מדבר על יחס איכות.מחיר) מכל EMP ו WaterChill .
Problem is i aint so sure my parents will order a 250$ package...
And with if somthing breaks or w/e who will i then turn for?
Id really perfer to order from a place that is close to me... like in my country....
יישור לשאמל!! >:(
כ"כ קשה? ברצינות?!
i was waitin for a comment... and this is the shit i get?
got a problem with my thread DONT READ IT
no point of makin such useless comment...
if cant contribue to my thread i dont care w/e u got to say...
if u did read what i said... seems u dont got anything helpful to say so why the hell r u tellin me to take it stright to left if u dont got any smart comment...
in this case take WaterChill
if u look in the forbidden site...
there r 5 kind of kits....
KT03-L20
KT15-L20
KT18-L20
KT12-L20
KT06-L20
prices in order are
1,004
1,124
1,124
1,194
997
1,031
whats the diff...?
and whats the best of de best?
with all 3 block ofcurse
as u can see the price dif betwen 2 and 3 blocks is near to zero, buy 3 blocks, its ashame that they dont have l-30 in israel
אם אתה מגיע למצב שהבלוק נשבר ,נוזל,נפגע - הדבר האחרון שיש לך לדאוג זה האחריות על הבלוק .
אין סיבה לקנות בלוק לגשר הצפוני, הירידה בביצועים של שאר המערכת תהיה הרבה יותר מורגשת מהתועלת הדי זניחה
So ur saying im better off with waterchill then emp...
then what waterchill model should i pick? i mean that have all 3 blocks... and everything...
And about the L30 in what way is it better then the L20?
I think i can talk them into ordering a kit from out of the country... but i dunno who does deliverys...
what site?
and what kit should i get?
what the best i can buy in israel
and whats the best i can order to israel and from where?
500$ TOP
but i know that higher value somtimes means crap...
thanks
Slim
what site?
500$ TOP
thanks
Slim
i sad it once and i'll say it again.
1. L-30 is better then L-20 becouse it has more l/hr (liter's pe hour)
2. waterchill the one with the 3 blocks
3. dangerden from USA
אתה קונה קירור כזה למעבד שבקושי תוכל להזיז אותו וזכרון שבקושי תוכל להרים
Well... קנה את ההכי יקר, הוא בטוח יהיה הכי טוב
כמו שחשבת שקנית את המחשב שלך
Ill do that
btw im changing my board to Epox 8rda3 plus
and buyin new OCZ memory...
mephisto as it seems u got no smart comment so instead of makin a smartass comment... just stay silent
