מהו עידכון KB2524375 ?
אם מישהו יודע מהו עידכון KB2524375 אשמח מאוד
I believe that this is in reponse to Comodo issuing several secuity certificates for several huge company names to a hacker by mistake.
So those certificat numbers are added to a blacklist (revocation list) so that if you run into a website trying to use one your broswer should block it with a popup asking you if you really want to go there. (It would almost assurably be a bad idea).
תודה, אז אני מבין שזה עידכון דיי טוב (עם הבערך אנגלית שאני מבין)
