פורסם 2011 במרץ 1215 שנים קיבלתי מסך כחול באמצע הורדה של משהו קטן 4MB בערך:ניתוח הMinidump: Microsoft (R) Windows Debugger Version 6.11.0001.404 X86Copyright (c) Microsoft Corporation. All rights reserved.Loading Dump File [C:\WINDOWS\Minidump\Mini031311-01.dmp]Mini Kernel Dump File: Only registers and stack trace are availableSymbol search path is: SRV*c:\websymbols*[url]http://msdl.microsoft.com/download/symbols[/url]Executable search path is: Windows XP Kernel Version 2600 (Service Pack 3) MP (2 procs) Free x86 compatibleProduct: WinNt, suite: TerminalServer SingleUserTSBuilt by: 2600.xpsp_sp3_gdr.101209-1647Machine Name:Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055d720Debug session time: Sun Mar 13 00:20:49.593 2011 (GMT+2)System Uptime: 0 days 4:50:14.284Loading Kernel Symbols.........................................................................................................................................Loading User SymbolsLoading unloaded module list............................******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************Use !analyze -v to get detailed debugging information.BugCheck 10000050, {e301901c, 0, bf846742, 1}Could not read faulting driver nameProbably caused by : win32k.sys ( win32k!RFONTOBJ::vXlatGlyphArray+5a )Followup: MachineOwner---------1: kd> !analyze -v******************************************************************************** ** Bugcheck Analysis ** ********************************************************************************PAGE_FAULT_IN_NONPAGED_AREA (50)Invalid system memory was referenced. This cannot be protected by try-except,it must be protected by a Probe. Typically the address is just plain bad or itis pointing at freed memory.Arguments:Arg1: e301901c, memory referenced.Arg2: 00000000, value 0 = read operation, 1 = write operation.Arg3: bf846742, If non-zero, the instruction address which referenced the bad memory address.Arg4: 00000001, (reserved)Debugging Details:------------------Could not read faulting driver nameREAD_ADDRESS: e301901c FAULTING_IP: win32k!RFONTOBJ::vXlatGlyphArray+5abf846742 8b470c mov eax,dword ptr [edi+0Ch]MM_INTERNAL_CODE: 1CUSTOMER_CRASH_COUNT: 1DEFAULT_BUCKET_ID: DRIVER_FAULTBUGCHECK_STR: 0x50PROCESS_NAME: chrome.exeLAST_CONTROL_TRANSFER: from bf89c267 to bf846742STACK_TEXT: a59e6c08 bf89c267 a59e6c30 00000001 a59e6c24 win32k!RFONTOBJ::vXlatGlyphArray+0x5aa59e6c28 bf953a1a 00000078 00000000 a59e6d1c win32k!RFONTOBJ::hgXlat+0x19a59e6cc4 bf94a82b e76536f8 00000078 00000000 win32k!GreGetGlyphOutlineInternal+0xa9a59e6d3c 8054167c f9010d4d 00000078 00000000 win32k!NtGdiGetGlyphOutline+0x85a59e6d3c 7c90e514 f9010d4d 00000078 00000000 nt!KiFastCallEntry+0xfcWARNING: Frame IP not in any known module. Following frames may be wrong.0013dbfc 00000000 00000000 00000000 00000000 0x7c90e514STACK_COMMAND: kbFOLLOWUP_IP: win32k!RFONTOBJ::vXlatGlyphArray+5abf846742 8b470c mov eax,dword ptr [edi+0Ch]SYMBOL_STACK_INDEX: 0SYMBOL_NAME: win32k!RFONTOBJ::vXlatGlyphArray+5aFOLLOWUP_NAME: MachineOwnerMODULE_NAME: win32kIMAGE_NAME: win32k.sysDEBUG_FLR_IMAGE_TIMESTAMP: 4d1dd63fFAILURE_BUCKET_ID: 0x50_win32k!RFONTOBJ::vXlatGlyphArray+5aBUCKET_ID: 0x50_win32k!RFONTOBJ::vXlatGlyphArray+5aFollowup: MachineOwner---------
