i need you help and your advise Smart Fan 2
shalom friends
I need your help and advise for fans for my coumpter case which one are the best and quiet size 80 mm
there is no problem for purchase of any amount I can afford any amount
thank you and you can write in hebrew
תחליף כותרת
ו Smart Fan 2
אם בא לך מאווררים עם לדים שיהיו יפים אז אני ממליץ בחום על
vantec UVled 80 mm פשוט תותחים...
Heh, if only vanted made some TMD fans that are 80mm :D
i think you meant to say is:
hello friends
I need your help and advice about fans for my coumpter case
which fans are the best and most quiet? their size should be 80 mm
price is no issue i can afford it
