Which of those heatsinks ?
Ok, I read maphisto's thread and it helped me a lot.. but then again.. there wasn't enough info..
Now i have three posebilities for CPU cooling, I'm not sure which one is better, which one is quieter and so on... so just answer my few questions please..
- SLK800 + SF2 - around 340 nis
- AX7 + SF2 (maybe a good combination ???) - around 250 nis
- AX7 + Delta Fan 80x80x38 , 80CFM, 52dBA - 248 nis
- SLK600 + Delta Fan 60x60 ,50.15 CFM, 54dBA - 242 nis
- Volcano 11 - 180 nis
- SK7 + Delta Fan 80x80x38 , 80CFM, 52dBA - 148 nis
1. Can you rank those from best to worst performace?
2. Can you rank them from the most noise making to the quietest?
They're listed from most expensive to cheapest.. and my budget is hurting me :-[
I only opened this thread because maphisto's thread doens't answer all my questions...
(another thing i'd accept happily, is advices for other kind of CPU cooling, quiet and efficient, from www.pandas.co.il preferably)
try getting slk800 + sf2
delta - TOO NOISY
delta - TOO NOISY
1. skorn ? :P shamen.
2. you didn't quite do what i asked in my post... telling me to buy the most expensive cooling isn't gonna help... >:(
גם אם זה היה עולה 50 שקל
זה עדיין הכי טוב מהאפשרויות שלך
אם לא זה אז ת AX + SF2
כי אני ממש לא אוהב את הדלטות
או שתחכה איזה שבועיים שיגיע לארץ VOLCANO 12
Ok, in maphisto's thread.. he mentions that the AX + a generic fan gets a 9.5 score under the quiet cooling..
same goes to the SK600 + delta fan on the noisy cooling...
the quesiton is: does that 9.5 mean the cooling level?
would you compare an SLK600 + delta fan to an AX7 + generic fan's cooling?
I tend to want the AX7 + SF2.... will that allow me to push my CPU to the limits?
*bump*
sorry, but i don't seem to be getting any attention.. please help me, it's important ..
SK7 + Delta & fanbas
or
SK7 + SF2
הAX 7 יותר טוב אבל תהיה לך בעיה להשיג אותו בארץ..
אין אותו בארץ
לא מבאים אותם לארץ עכשיו!!
אני ניסיתי לקנות אותו הודיעו לי שאין בארץ!
והשאלה שלי שגם אני מעונין לקנות
איזה היסטינג כדי לקנות????
הייתי לוקח את הSK-7 & SF2.
