CPU Temperatures rising for no reason :\
Ok, here goes:
A while ago I opened a thread asking how to clear my airflow and i did it correctly...
then I checked my CPU temperature and had a nice (and pretty amazing actually) 32c degrees with my AMD stock cooling...
then i realized i didn't put my DDR on the dual DDR slots and i fixed that, and in the same opertunity i rearranged some cables in my case..
now all of a sudden my CPU reaches temperatures such as 40... at idle and maybe 50 at work..
what can be the cause? help me please :(
I plan to buy a new CPU cooling soon
either the SLK800/600 + Tt SF2 or the Tt Volcano 11
but i still want to optimize everything else but the CPU cooling itself..
Well...
I assume that your problam comes from the Dual DDR.
And why is that ?, the Dual DDR is known by its hot "temper" what makes the temps to rise on the north bridge and maybe its causing the temps sensor to get a wrong measurements.
Be The Way, on a AMD system Dual DDR wont grant you much better performance (maybe 5%) so i think that u can move back to single DDR channel.
ok, I just orginized my case a little more, moved to single DDR channel and my CPU temp is down to 38c...
still not as satisfying :\
But hey, i guess that's pretty fucking good for stock cooling :D
now it's time to bring in the cavalery (my new CPU cooling)
