Orginizing my case...
In what ?... the post? :\
Ok, i'm confused :P
can you explain to me where to check if my dual DDR is enabled? and if it's not i'll change it like you said?
the thing is, the slots i put my memmories in are close together, and the 3rd slot is a bit far off from them... i thought that they're being put together to indicate something 8)
anyways, In my computer's picture.. there's cables from the PSU rounded up in some kind of "net", any of you knows where i can get such thing?
another thing, here's a report about my CPU from a program i downloaded:
AMD Athlon XP 2500+, 1829MHz, 512KB (0% Load) @ 32°C (Fan @ 2986 RPM), Core @ 1.664V / Case @ 21°C
  • תגובות 38
  • צפיות 2.3k
במסך הראשוני שעולה, בו נבדקת כמות הזכרון הפנימי והכוננים וכו'...
well, it says DDR 333mhz
and later on indicates it's 512MB
but i can't see it, it's too fast.. so i can't see if it's dual ddr or not :\
(oh and, quick reply :P)
what about CS, rockford... got frag ? :D
תשים את הסטיקים ב Dimmz 3 & 1/3 & 2 וזה יתאפשר אוטומאטית (תוצג הודעה שמודיעה על כך, בספק אם תפספס אותה).
ok, i'll check now..
I wanted a good chance to turn off the computer anyways, cuz i need to fold up a few more cables inside the case :D
my goal: 30 degrees...
בהחלט מרשים, בהתחשב בכך שאתה משתמש בקירור סטוק.
Stock cooling ? what's that ?
ok so here goes - i switched the memmory slots and indeed the computer indicated that the dual DDR is on, but for some reason i feel the computer working a little slower... or maybe it's just me :\
anyways, the 30 degrees i reffered to were in idle, not when i use the computer heavily :P
קירור סטוק - הכוונה לקירור המקורי שהגיע עם הברטון שלך.
וכשאתה מאמץ אותו למשך כמה דקות טובות, מהי הטמפ'?
i just attempted a nice render on 3d studio max, the temperature right now is:
AMD Athlon XP 2500+, 1829MHz, 512KB (0% Load) @ 40°C (Fan @ 2934 RPM), Core @ 1.632V / Case @ 23°C
Is there any way to make the case fans work faster?
