2.4Ghz 1000mW/1W Wireless Ultra Range Extender for Wifi/WLAN Access Points AP an
מישהו יכול להסביר לי מה אומר המוצר הזה ?
ומה זה DBM30
2.4Ghz 1000mW/1W Wireless Ultra Range Extender for Wifi/WLAN Access Points AP and Routers
Model: 2.4GHz ARG1105
- Amplifies 802.11b/g wireless network/broadband (WLAN/Wifi) signals
- Whopping 1W/1000mW power output rating
- Bi-directional amplification (only need to install one amplifier in the network/on the router/AP for all clients to benefit from the added signal strength)
- Works with both access points (AP), wireless routers, and wifi adapter cards
- Supports standard SMA antenna connectors
- Dramatically improved network coverage and range
- 30dBm (1W) output
- Supports IEEE802.11b/g
- Amplification frequency range: 2400MHz ~ 2500MHz
- Supports both unidirectional and omnidirectional antennas
- 100V~240V AC adapter included
- English user's guide included
- High gain long range antenna and connection cable included
- To use, simply remove the original antenna from your router/ap/wifi card, then connect the SMA connection cable to the router/ap/wifi card's antenna port.[ftp=ftp://]]][/ftp]
לפי התיאור זה מגבר לאות אלחוטי. באופן פשטני ניתן להגדיר את ה-30dBm כעוצמת ההגברה שלו. ערך כזה אינו חוקי במדינת ישראל.
