Slow internet - part 2
Well, in continuation to my previous thread, the problem is not in the LAN card and not in the ISP, when I changed the computer the connection became slow, but I took my previous lan card and I imported it into my computer and guess what? it has nothing to do with the lan card. I called my ISP aswell, and they donno what is the problem (and yes, my dsl is still on 1.5Mbit), so here comes the question, WHAT MAKES MY INTERNET GO IN HALF SPEED? I am begging for your help people im desperet, If you can, please write me in HEBREW, thx
אתה בטוח שה MTU וה TCP RW מכוון ?
כי יכל להיות שפשוט זה מה שמגביל אותך ... הנה תוכנה :
TCP Optimizer
What should I change in the program?
אני לא מאמין שהגדרות MTU וכדומה יכולות להגביל את החיבור עד כדי כך... אבל מי יודע... תנסה...
Nothing had changed! :'(
Anyone with DSL @ Bezeqint @ 1.5Mbit connection in here? if yes, what is your avarage download speed?
