אפשרויות Scale ב-Catalyst
אני חייב את האפשרות Scale ב-Catalyst ואין לי אותה.
היא אמורה להיראות ככה:
לפי מה שקראתי ברשת, כל עוד אין לי את האפשרות הזאת, ברזולוציה של 1080P, השוליים של המסך יוצאים מחוץ למסך עצמו...
תשתמש באפליקציה הבאה - ATIGPUScalingFix .
אחרי שתעקוב אחרי ההוראות תוכל לפתור את הבעיה המטרידה.
ATI GPU Scaling Fix v1.1 for Windows 7
by AgentGOD
Homepage: www.ultimate-filez.com
Donation: www.ultimate-filez.com/?page=donate
Description:
A fix for the infamous GPU Scaling issue with ATI Catalyst and Windows 7. See below for
more details.
Requirements:
- An x86/x64 CPU.
- A DVI/HDMI/DisplayPort monitor. CRT will not work.
- Microsoft® Windows 7. Both x86 and x64 should be supported. Tested on x64.
- Latest ATI Catalyst drivers.
- Microsoft® Visual C++ 2008 Runtime (x86), can be found here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf
- Microsoft® .NET Framework v2.0 (minimum), can be found here:
http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5
Note:
- If you have not checked "Enable GPU Scaling" in Catalyst Control Center, you must do so first.
- This program has only been tested on one machine (AMD Turion Ultra X2 laptop with HD 3200 IGP),
so please don't hesitate to give positive constructive feedback!
*v1.1 has been heavily optimized on a gaming desktop with multiple monitors, so it should work on all setups now
Usage:
- Run the program.
- Select the desired GPU Scaling mode.
- Run your favorite 3D application (such as a game, etc).
- Enjoy. Please everyone submit tickets to the Catalyst crew feedback system!
- Please donate if you like this program and/or my other programs!
If you need any more information or help, click the "Help" button in the program. If that
is not helpful enough, feel free to post on the forums!
Copyright © 2010 Ultimate Filez
ATI Catalyst is a trademark of Advanced Micro Devices.
[attachment deleted by admin]
תשמע, התוכנה לא עושה כלום.
הפעלתי אותה, סימנתי את ההגדרה שאני רוצה ופשוט לא קורה כלום, המסך לא משתנה ולא כלום ולמעשה לא כתוב בהוראות לעשות שום דבר אחר...[br]פורסם בתאריך: 20.08.2010 בשעה 11:27:57
כתוב בהוראות:
אין לי את הפונקציה הזאת בכלל...
[br]פורסם בתאריך: 20.08.2010 בשעה 11:31:36
עדכון:
מסתבר ש-Catalyst מזהה לי את המסך כ-CRT בכלל...
יש לך מושג איך מתקנים את זה?
