עזרה בהתקנת via s3g unichrome pro igp
יש לי בעיה בהתקנת הדרייבר הנ"ל. מצאתי את הדרייברים המתאימים, אך בכל פעם שאני מנסה להתקין, מופיע לי s3iscfg.log שגיאה:
S3 GRAPHICS SETUP LOG - Started 2010/07/13 11:37:09 **********
***** Please scroll to the end of *****
***** this document for the results. *****
S3Iset32 v2.00.23-1018B, (S3GSetup/IS10 2.00.23-1018B)
System: Win XP SP2 Build 2600 (Service Pack 3, v.5938)
Signature: 15-9956 (ANSI)
Caller cmdline: ''
SupportDir: 'C:\DOCUME~1\nadav\LOCALS~1\Temp\S3M23.tmp\'
Called by custom setup app.
AllowReboot: TRUE
Prompt: TRUE
SilentReboot: TRUE
Prompt: FALSE
RemoveWinINF: FALSE
PreInstFiles: FALSE
No UI Reboot: FALSE
MenuAnimOff: FALSE
MenuShadowOff: FALSE
Find VendorID: 5333
Driver INF at: C:\Drivers\video_VIA_K8M800\uc03i.inf
Find hardware code->0
Custom uninstall info: C:\WINDOWS\UChromeP.uns
Hardware found - Ven:1106 Dev:3343 Ssven:147B Ssdev:1422 Rev:01 Location: bus 1 dev 0 func 0 (InVga=1)
************** Begin Win2K/XP Driver Install **************
Enum GUID {4d36e968-e325-11ce-bfc1-08002be10318} devs to match 'PCI\VEN_1106&DEV_3343&SUBSYS_1422147B&REV_01':
Enum done.
Could not find enum device to match hardware.
Enumerating all Enum\PCI registry entries...
Device #0 subkey: "VEN_10EC&DEV_8139&SUBSYS_1422147B&REV_10"
Device #1 subkey: "VEN_1106&DEV_0327&SUBSYS_00000000&REV_00"
Device #2 subkey: "VEN_1106&DEV_0571&SUBSYS_1422147B&REV_06"
Device #3 subkey: "VEN_1106&DEV_1327&SUBSYS_00000000&REV_00"
Device #4 subkey: "VEN_1106&DEV_2327&SUBSYS_00000000&REV_00"
Device #5 subkey: "VEN_1106&DEV_3038&SUBSYS_1422147B&REV_81"
Device #6 subkey: "VEN_1106&DEV_3059&SUBSYS_1422147B&REV_60"
Device #7 subkey: "VEN_1106&DEV_3104&SUBSYS_1422147B&REV_86"
Device #8 subkey: "VEN_1106&DEV_3149&SUBSYS_1422147B&REV_80"
Device #9 subkey: "VEN_1106&DEV_3227&SUBSYS_00000000&REV_00"
Device #10 subkey: "VEN_1106&DEV_3327&SUBSYS_00000000&REV_00"
Device #11 subkey: "VEN_1106&DEV_3343&SUBSYS_1422147B&REV_01"
Found matching hardware!
Found Inst=PCI\VEN_1106&DEV_3343&SUBSYS_1422147B&REV_01\4&354aea31&0&0008.
Found Mfg line: 'VIA.Mfg'.
Ln 0: 'viagfx_3204,PCI\VEN_1106&DEV_3108'
!! INF does not describe detected hardware!!
Device or vendor ID (or subsystem) mismatch!!
StopTimer OK, but no timer action occurred.
-> Setup was unable to complete the installation.
-> Setup was unable to complete the installation. Check the progress log in your Windows directory for more details. (-5)->C:\WINDOWS\s3iscfg.log
** Installation Failed **
!! Setup was aborted !!
******** End of progress log ********
