buying in 3 days.. feedbacks plz
so im about to buy my second rig from KSP and this is the rig
CPU: Core i5 750, 2.66GHz, s1156, 8MB Tray
CPU FAN: Thermaltake Silent 1156 CLP0552
M.Board: GIGABYTE P55M-UD2
Memory: DDR III 1333Mhz 2x2GB G.Skill NQ Edition Dual Channel
VGA: GIGABYTE HD 5770 1GB
HDD: Western Digital Caviar Green 500GB IntelliPower, 32MB
Optical Writer: Samsung SH-S223B DVD±RW x22 Black SATA
Power Supply: SeaSonic 620W Modular 80+ Bronze Active PFC 12cm Fan M12II-620 (Retail)
Case: CoolerMaster CM 690 II Plus Black
well this is it im pretty locked on everything but plz do leave comment and ideas for improvements
thanks in advance yours Grasec
BTWmy top budget is around 4.4-5k so yeah dont go too wild if ull advice some other build
סה"כ המפרט נראה לא רע פרט לספק הכח שהוא די אוברקיל למערכת הנ"ל.
כך או כך חסרים הרבה פרטים לגבי שימושים והעדפות, ענה בבקשה על השאלה שבלינק הבא ושנה את הכותרת ליותר אינפורמטיבית (ציין שימושים+תקציב) אחרת לא נוכל לעזור לך והדיון ינעל. הכל פה- http://hwzone.co.il/community/index.php?topic=51049.0
k, im buyin this pc mostly for gaming the overkilled PSU is for future upgrades like getin more powerful VGAs addin more HDDs and accessories like light and led fans everywhere idk bout that yet but a good PSU is never a waste
so yeah my mostly gaming dont need everythign on super duper high i'll sattle for high with 4xAA and like im getin my 24" next month so meanwhile it'll run ona 19" 1280x1024
budget... 4.4-4.5k NIS
stores.. mainly KSP cuz they are close and wont run anywhere like tms&fox
but if u know about some store which is highly reliable id like to see an offer containing these parts from there
as in the lables cpu goes INTEL only i got my last rig the phenomII 720 BE works fine and all but sometimes when runnin like gta4 while waiting for a GW in Aion it crashes the whole system and stuff like crysis + Aion = Blue Screen idk maybe its my spesific core that causes these problems but still id rather go with intel for now VGA ati for me now i have the GTX260 core 216 it is awesome off the hook but.. its very hot gets to like 85-90 Co and that doesnt work for me
one more thing the caviar green WDs are way way better than the black ones ik they spin slower but that onyl means they are quiet cuz the blacks go 7200rpm the get to the point where the data should be read b4 its there and they it just waits for it the greens get to the piont just in time when the data gets there so that makes them better quieter and consume less energy.. as in for the case.. i will not sattle for any other case if its not mid tower so freakin awesome for cable managment like the CM 690 II plus/advanced and at the price range of 450 tops
so there ya go all the info ya need i think O.o
טוב אז ככה, סה"כ מפרט טוב אך יש לי כמה הערות קטנות:
-קירור ניתן להחליף לפריזר 7 פרו (גרסא שניה, עולה בקייאספי 125 שקלים) וזה קירור שגם נחשב לשקט וגם מקרר בצורה טובה יותר מהTT שבחרת.
-בנוגע לכרטיס המסך הנוכחי שלך (GTX260) בדוק אם הקירור שלו יושב טוב עליו והוא נקי מאבק בפנים. שנה גם את מהירות המאוורר לאיזה 20% יותר- אם יש לך קירור סטוק לא אמור להיות שינוי משמעותי ברעש אבל הטמפרטורות במאמץ (וגם במנוחה) יהיו נמוכות יותר.
-שמעתי ממספר חנויות כי ישנה בעיה פה ושם עם סדרת הספקים הזה (M/S12II), לכן שאל בחנות אם זה נכון. במידה וכן קח ספק מסדרת ECO של אנרמקס.
the ECO series arnt modular.. and im getin the CM 690II only cuz its so good for cable management and getin a non modular PSU would be a dumb thing to do if ur planin on not seeing any cables inside ur case.. tho its possible to hide all the extra cables from a non modular PSU but it take more time and then it looks messy on the back.. so i thought getin the CoolerMaster Silent Pro 600W Modular 13.5cm Fan its 600W it has flat black cables wich are great for my plans and far as i know it has Xfire/SLI ready so it wont have any problem servin me in the next couple of years what u think?
