פורסם 2010 באפריל 816 שנים משום מה הדרייבר שמצאתי לא מתאים למרות שהוא אמור להתאים.אולי אני טועהמצטער על האינפו הלא רלוונטיהכרטיס עצמאי.לא מובנה בלוח--------[ EVEREST Corporate Edition ]----------------------------------------------------------------------------------- Version EVEREST v5.30.1900/he Benchmark Module 2.4.273.0 Homepage http://www.lavalys.com/ Report Type Quick Report Computer PASCAL Generator Ayal Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP RTM) Date 2010-04-07 Time 21:11--------[ CPU ]--------------------------------------------------------------------------------------------------------- CPU Properties: CPU Type Intel Pentium 4, 3000 MHz CPU Alias Prescott-2M CPU Stepping N0 Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3 Original Clock 3000 MHz L1 Trace Cache 12K Instructions L1 Data Cache 16 KB L2 Cache 2 MB (On-Die, ECC, ATC, Full-Speed) Multi CPU: Motherboard ID Grantsdale-G CPU #1 Intel® Pentium® 4 CPU 3.00GHz, 3000 MHz CPU #2 Intel® Pentium® 4 CPU 3.00GHz, 3000 MHz CPU Physical Info: Package Type 775 Contact LGA Package Size 3.75 cm x 3.75 cm Transistors 169 million Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si Die Size 135 mm2 Core Voltage 1.3 V I/O Voltage 1.3 V Typical Power 84 W @ 3.00 GHz Maximum Power 101 W @ 3.00 GHz CPU Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/processor CPU Utilization: CPU #1 / HTT Unit #1 0 % CPU #1 / HTT Unit #2 0 %--------[ CPUID ]------------------------------------------------------------------------------------------------------- CPUID Properties: CPUID Manufacturer GenuineIntel CPUID CPU Name Intel® Pentium® 4 CPU 3.00GHz CPUID Revision 00000F43h IA Brand ID 00h (Unknown) Platform ID FFh (Unknown) HTT / CMP Units 2 / 1 Instruction Set: 64-bit x86 Extension (AMD64, Intel64) Supported AMD 3DNow! Not Supported AMD 3DNow! Professional Not Supported AMD 3DNowPrefetch Not Supported AMD Enhanced 3DNow! Not Supported AMD Extended MMX Not Supported AMD MisAligned SSE Not Supported AMD SSE4A Not Supported AMD SSE5 Not Supported Cyrix Extended MMX Not Supported IA-64 Not Supported IA MMX Supported IA SSE Supported IA SSE 2 Supported IA SSE 3 Supported IA Supplemental SSE 3 Not Supported IA SSE 4.1 Not Supported IA SSE 4.2 Not Supported IA AVX Not Supported IA FMA Not Supported IA AES Extensions Not Supported VIA Alternate Instruction Set Not Supported CLFLUSH Instruction Supported CMPXCHG8B Instruction Supported CMPXCHG16B Instruction Supported Conditional Move Instruction Supported LZCNT Instruction Not Supported MONITOR / MWAIT Instruction Supported MOVBE Instruction Not Supported PCLMULQDQ Instruction Not Supported POPCNT Instruction Not Supported RDTSCP Instruction Not Supported SYSCALL / SYSRET Instruction Not Supported SYSENTER / SYSEXIT Instruction Supported VIA FEMMS Instruction Not Supported Security Features: Advanced Cryptography Engine (ACE) Not Supported Advanced Cryptography Engine 2 (ACE2) Not Supported Data Execution Prevention (DEP, NX, EDB) Supported Hardware Random Number Generator (RNG) Not Supported PadLock Hash Engine (PHE) Not Supported PadLock Montgomery Multiplier (PMM) Not Supported Processor Serial Number (PSN) Not Supported Power Management Features: Automatic Clock Control Supported Digital Thermometer Not Supported Dynamic FSB Frequency Switching Not Supported Enhanced Halt State (C1E) Not Supported Enhanced SpeedStep Technology (EIST, ESS) Supported Frequency ID Control Not Supported Hardware P-State Control Not Supported LongRun Not Supported LongRun Table Interface Not Supported PowerSaver 1.0 Not Supported PowerSaver 2.0 Not Supported PowerSaver 3.0 Not Supported Processor Duty Cycle Control Supported Software Thermal Control Not Supported Temperature Sensing Diode Not Supported Thermal Monitor 1 Supported Thermal Monitor 2 Supported Thermal Monitoring Not Supported Thermal Trip Not Supported Voltage ID Control Not Supported CPUID Features: 1 GB Page Size Not Supported 36-bit Page Size Extension Supported Address Region Registers (ARR) Not Supported CPL Qualified Debug Store Supported Debug Trace Store Supported Debugging Extension Supported Direct Cache Access Not Supported Dynamic Acceleration Technology (IDA) Not Supported Fast Save & Restore Supported Hyper-Threading Technology (HTT) Supported, Enabled Invariant Time Stamp Counter Supported L1 Context ID Supported Local APIC On Chip Supported Machine Check Architecture (MCA) Supported Machine Check Exception (MCE) Supported Memory Configuration Registers (MCR) Not Supported Memory Type Range Registers (MTRR) Supported Model Specific Registers (MSR) Supported Nested Paging Not Supported Page Attribute Table (PAT) Supported Page Global Extension Supported Page Size Extension (PSE) Supported Pending Break Event Supported Physical Address Extension (PAE) Supported Safer Mode Extensions (SMX) Not Supported Secure Virtual Machine Extensions (Pacifica) Not Supported Self-Snoop Supported Time Stamp Counter (TSC) Supported Turbo Boost Not Supported Virtual Machine Extensions (Vanderpool) Not Supported Virtual Mode Extension Supported x2APIC Not Supported XSAVE / XRSTOR Extended States Not Supported CPUID Registers (CPU #1): CPUID 00000000 00000005-756E6547-6C65746E-49656E69 CPUID 00000001 00000F43-00020800-0000649D-BFEBFBFF CPUID 00000002 605B5001-00000000-00000000-007D7040 CPUID 00000003 00000000-00000000-00000000-00000000 CPUID 00000004 00004121-01C0003F-0000001F-00000000 CPUID 00000004 00004143-01C0103F-000007FF-00000000 CPUID 00000005 00000040-00000040-00000000-00000000 CPUID 80000000 80000008-00000000-00000000-00000000 CPUID 80000001 00000000-00000000-00000000-20100000 CPUID 80000002 20202020-20202020-20202020-6E492020 CPUID 80000003 286C6574-50202952-69746E65-52286D75 CPUID 80000004 20342029-20555043-30302E33-007A4847 CPUID 80000005 00000000-00000000-00000000-00000000 CPUID 80000006 00000000-00000000-08006040-00000000 CPUID 80000007 00000000-00000000-00000000-00000000 CPUID 80000008 00003024-00000000-00000000-00000000 CPUID Registers (CPU #2 Virtual): CPUID 00000000 00000005-756E6547-6C65746E-49656E69 CPUID 00000001 00000F43-01020800-0000649D-BFEBFBFF CPUID 00000002 605B5001-00000000-00000000-007D7040 CPUID 00000003 00000000-00000000-00000000-00000000 CPUID 00000004 00004121-01C0003F-0000001F-00000000 CPUID 00000004 00004143-01C0103F-000007FF-00000000 CPUID 00000005 00000040-00000040-00000000-00000000 CPUID 80000000 80000008-00000000-00000000-00000000 CPUID 80000001 00000000-00000000-00000000-20100000 CPUID 80000002 20202020-20202020-20202020-6E492020 CPUID 80000003 286C6574-50202952-69746E65-52286D75 CPUID 80000004 20342029-20555043-30302E33-007A4847 CPUID 80000005 00000000-00000000-00000000-00000000 CPUID 80000006 00000000-00000000-08006040-00000000 CPUID 80000007 00000000-00000000-00000000-00000000 CPUID 80000008 00003024-00000000-00000000-00000000--------[ Motherboard ]------------------------------------------------------------------------------------------------- Motherboard Properties: Motherboard ID 63-0100-000001-00101111-060904-iSPGDL_G$CY915001_BIOS DATE: 06/09/04 18:06:30 VER: 08.00.10 Motherboard Name Intel Cherry Creek D915PCY Motherboard Physical Info: CPU Sockets/Slots 1 LGA775 Expansion Slots 4 PCI, 2 PCI-E x1, 1 PCI-E x16 RAM Slots 4 DDR2 DIMM Integrated Devices Audio, LAN Form Factor ATX Motherboard Size 240 mm x 300 mm Motherboard Chipset i915P Motherboard Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/motherboard/index.htm BIOS Download http://downloadcenter.intel.com/default.aspx Driver Update http://driveragent.com?ref=59 BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40--------[ Memory ]------------------------------------------------------------------------------------------------------ Physical Memory: Total 509 MB Used 149 MB Free 359 MB Utilization 29 % Swap Space: Total 1246 MB Used 86 MB Free 1159 MB Utilization 7 % Virtual Memory: Total 1755 MB Used 236 MB Free 1519 MB Utilization 13 % Paging File: Paging File C:\pagefile.sys Initial / Maximum Size 768 MB / 1536 MB Current Size 768 MB Current / Peak Usage 8 MB / 8 MB Utilization 1 % Physical Address Extension (PAE): Supported by Operating System Yes Supported by CPU Yes Active No--------[ Chipset ]----------------------------------------------------------------------------------------------------- [ North Bridge: Intel Grantsdale i915P ] North Bridge Properties: North Bridge Intel Grantsdale i915P Revision / Stepping 00 / A0 Chipset Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/chipsets Driver Download http://support.intel.com/support/chipsets BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40 Driver Update http://driveragent.com?ref=59 [ South Bridge: Intel 82801FB ICH6 ] South Bridge Properties: South Bridge Intel 82801FB ICH6 Revision / Stepping D3 / B1 Chipset Manufacturer: Company Name Intel Corporation Product Information http://www.intel.com/products/chipsets Driver Download http://support.intel.com/support/chipsets BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40 Driver Update http://driveragent.com?ref=59--------[ BIOS ]-------------------------------------------------------------------------------------------------------- BIOS Properties: BIOS Type AMI BIOS Version CY91510A.86A.0012.2004.0609.1806 System BIOS Date 06/09/04 Video BIOS Date 05/03/04 BIOS Manufacturer: Company Name American Megatrends Inc. Product Information http://www.ami.com/amibios BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40--------[ ACPI ]-------------------------------------------------------------------------------------------------------- [ RSD PTR: Root System Description Pointer ] ACPI Table Properties: ACPI Signature RSD PTR Table Description Root System Description Pointer Memory Address 000F4E50h Table Length 36 bytes OEM ID ACPIAM--------[ Debug - PCI ]------------------------------------------------------------------------------------------------- B01 D00 F00: Tul Radeon X300 SE Video Adapter Offset 000: 02 10 60 5B 00 00 00 00 00 00 00 03 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
פורסם 2010 באפריל 816 שנים 32 ביטhttps://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-2_legacy_vista32-64_dd_ccc.exe64 ביטhttps://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-2_legacy_vista32-64_dd_ccc.exe
פורסם 2010 באפריל 816 שנים מחבר תודה רבה!משום מה זה מפנה אותי לדף ראשי ללא סיומת exeאם מדובר בשני אלה מכאןhttp://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.21〈=Englishזה אלה שלא התאימו והם מחשיכים את המסך לאחר התקנה
