Altec Lansing פונה לנגנים
Altec Lansing inMotion Portable iPod Speakers
This tiny, ultra-portable, battery-operated stereo system is the first powered audio system designed exclusively for the iPod. A highly efficient amplifier powers four full-range micro drivers to deliver a full spectrum of pure, distinct sound, while the revolutionary MaxxBass technology allows listeners to enjoy deep bass without lugging large speakers around. Best of all, connectivity is as easy as placing your iPod into the built-in dock or connecting it through the auxiliary port.
The inMotion portable audio system supports all iPods. (iPod with Dock connector as well as iPod with FireWire connector)
Applications:
Top quality portable speakers for use in office or hotel room
Travel alarm clock when used with Pod
Charges the iPod through the built-in dock
Syncs the iPod through the built in dock or FireWire port
Supports audio input from other devices (PowerBook or iBook)
Support audio output to home stereo systems (cable sold separately)
Features:
Surprisingly Powerful - Highly efficient digital amplifier (Class D) produces maximum power.
Big Sound in Small Footprint - High-performance, custom-designed neodymium Micro Drivers deliver crystal clear sound.
Revolutionary MaxxBass technology - Creates deep bass without a subwoofer.
Built-in Dock - Provides same synchronization and data transfer options as your iPod dock (cable not included) and allows you to recharge your iPod.
Extra long battery life - Delivers up to 24 hours of continuous playback with four AA batteries (not included).
Ultra-portable - Lightweight design folds to close at 15 ounces and 8 inches wide, 5.4 inches deep and 1.2 inches thick.
Auxiliary input jack: for connection with other audio devices, including laptops, older iPods, and other MP3 players (3.5mm stereo cable included).
Elegant, integrated controls: Power and volume.
Headphone jack: For private listening.
Altec Lansing's superior sound comes from proprietary technology, which utilizes custom-built, high-fidelity drivers, state-of-the-art equalization circuitry, and a harmonious mix of the following specifications:
Total Continuous Power: 4 Watts RMS
Front Speakers: 2 Watts/channel @ 8 ohms @ 10% THD @ 20 - 20000 Hz 2 Channels
System Response: 60 Hz - 20 kHz
Signal to Noise Ratio @ 1 kHz input: > 75 dB
Drivers (per Satellite): Four 1" full-range neodymium Micro Drivers
Dimensions: 8" (W) x 5.4" (D) x 1.2" (H)
http://store.apple.com/1-800-MY-APPLE/WebObjects/AppleStore.woa?productLearnMore=T8355LL/A
נחמד מאד... 8)
150$...טוב, כל המוצרים הנלווים לאיי-פוד הם יקרים בצורה מטורפת.
