בעיית DMA-driver error, CRC error ב-Nero
התקנתי היום את ה-GH22LS50 שלי, כשאני מנסה לצרוב CD-R אני נתקע ב-6% ומקבל את הלוג הבא -
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 9.0.9.100
Internal Version: 9, 0, 9, 100
Recorder: <HL-DT-ST DVDRAM GH22LS50>Version: TL01 - HA 1 TA 0 - 9.0.9.100
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default
CD-ROM: <NWB HQZSTY3K >Version: 1.03 - HA 1 TA 1 - 9.0.9.100
=== Scsi-Device-Map ===
CdRomPeripheral : HL-DT-ST DVDRAM GH22LS50 atapi Port 2 ID 0 DMA: Off
DiskPeripheral : Hitachi HDP725050GLA360 atapi Port 5 ID 0 DMA: On
CdRomPeripheral : MagicISOVirtual DVD-ROM 1.0A mcdbus Port 6 ID 0 DMA: Off
CdRomPeripheral : NWB HQZSTY3K 1.03 afolkhdx Port 7 ID 0 DMA: Off
CdRomPeripheral : NWB HQZSTY3K 1.03 afolkhdx Port 7 ID 1 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST DVDRAM GH22LS50 E: CdRom0
NWB HQZSTY3K F: CdRom1
NWB HQZSTY3K G: CdRom2
MagicISO Virtual DVD-ROM H: CdRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 2046MB (2095340kB)
Free physical memory: 1153MB (1181028kB)
Memory in use : 43 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
15.12.2009
CD-ROM (ISO)
14:41:38 #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
14:41:38 #2 Text 0 File Isodoc.cpp, Line 6789
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : FALSE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
14:41:38 #3 Text 0 File Burncd.cpp, Line 3233
Buffer underrun protection activated
14:41:38 #4 ISO9660GEN -11 File Geniso.cpp, Line 3349
First writeable address = 0 (0x00000000)
14:41:38 #5 Text 0 File ThreadedTransferInterface.cpp, Line 1029
Removed 2 run-out blocks from end of track 0. Length: 358856 -> 358854.
14:41:38 #6 Text 0 File Burncd.cpp, Line 3563
Turn on Track-At-Once, using CD-R/RW media
14:41:38 #7 Text 0 File ThreadedTransferInterface.cpp, Line 1029
Removed 2 run-out blocks from end of track 1. Length: 358856 -> 358854.
14:41:38 #8 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorCD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
14:41:38 #9 Text 0 File ThreadedTransferInterface.cpp, Line 1029
14:41:38 #10 Text 0 File DlgWaitCD.cpp, Line 312
Last possible write address on media: 359845 ( 79:59.70)
Last address to be written: 358855 ( 79:46.55)
14:41:38 #11 Text 0 File DlgWaitCD.cpp, Line 324
Write in overburning mode: NO (enabled: CD)
14:41:38 #12 Text 0 File DlgWaitCD.cpp, Line 2951
Recorder: HL-DT-ST DVDRAM GH22LS50;
CDR code: 00 97 26 66; OSJ entry from: CMC Magnetics Corporation
ATIP Data:
Special Info [hex] 1: D0 00 98, 2: 61 1A 42 (LI 97:26.66), 3: 4F 3B 47 (LO 79:59.71)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
14:41:38 #13 Text 0 File DlgWaitCD.cpp, Line 499
>>> Protocol of DlgWaitCD activities: <<<
14:41:38 #14 Text 0 File ThreadedTransferInterface.cpp, Line 756
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 358856 (358856) = #358856/79:44.56
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 358854 blocks [E: HL-DT-ST DVDRAM GH22LS50]
14:41:38 #15 Text 0 File ThreadedTransferInterface.cpp, Line 958
Prepare [E: HL-DT-ST DVDRAM GH22LS50] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 735244288, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 358856 | 0 | 0x00
358856 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
14:41:38 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1029
14:41:44 #17 Text 0 File SCSIPTICommands.cpp, Line 264
Error on LockVolume: ‏‏הגישה נדחתה.
14:41:44 #18 Text 0 File SCSIPTICommands.cpp, Line 314
SPTI - Error 5 on DismountVolue: ‏‏הגישה נדחתה.
14:41:49 #19 Text 0 File SCSIPTICommands.cpp, Line 264
14:41:49 #20 Text 0 File Burncd.cpp, Line 4362
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
14:41:49 #21 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
14:41:49 #22 Text 0 File Burncd.cpp, Line 4484
Cache writing successful.
14:41:49 #23 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
14:41:49 #24 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 48x (7,200 KB/s)
14:41:49 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2675
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:41:49 #26 Text 0 File MMC.cpp, Line 22511
Set BUFE: Buffer underrun protection -> ON
14:41:49 #27 Text 0 File ThreadedTransfer.cpp, Line 273
Pipe memory size 83836800
14:41:59 #28 SPTI -1502 File SCSIPassThrough.cpp, Line 215
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1502)
CDB Data: 0x2A 00 00 00 00 00 00 00 20 00 00 00
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x08
Sense Qual: 0x03
Sense Area: 0x70 00 04 00 00 00 00 0A 88 BA 58 80 08 03
Buffer x085e0040: Len x10000
0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
14:41:59 #29 CDR -1502 File Writer.cpp, Line 306
14:42:05 #30 CDR -201 File WriterStatus.cpp, Line 325
Invalid write state
14:42:05 #31 TRANSFER -18 File WriterStatus.cpp, Line 325
Could not perform EndTrack
14:42:05 #32 Text 0 File MMC.cpp, Line 17309
<HL-DT-STDVDRAM GH22LS50 > start Close Track #2
14:42:26 #33 Text 0 File DVDPlusDualLayer.cpp, Line 1424
SetDriveCaps: Set LAST LBA of layer 1 to 0
14:42:26 #34 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 48x (7,200 KB/s)
14:42:26 #35 Text 0 File SCSIPTICommands.cpp, Line 314
14:42:26 #36 Text 0 File Cdrdrv.cpp, Line 11444
DriveLocker: UnLockVolume completed
14:42:26 #37 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
מה הבעיה בדיוק?
עשיתי בכולם, בכולם המצב הוא "לא ישים".
תעלה תמונה בבקשה. איזה לוח אם יש לך?
GA-EG45M-DS2H Gigabyte
יש שם עוד ערוצים.. תבדוק בכולם. או שפשוט תכנס שוב לקישור שהביא ag43.. בתחילת ההודעה יש קישור לסקריפט שיעשה לך את העבודה.
טעות שלי, חשבתי שמדובר בצורב IDE, בצורבי SATA אין אפשרות לשנות את האפשרות הזו. תנסה מספר דברים:
1. תנסה תוכנת צריבה אחרת.
2. תסיר (UNINSTALL) ממנהל ההתקנים את הצורב, תפעיל את המחשב מחדש ותראה אם משהו השתנה.
3. תחליף כבל DATA של הצורב\תחבר לחיבור אחר בלוח האם.
4. אתה באוברקלוק?
בגדול אין אבל כיום רובם עובדים עם אמולציה של IDE.. אז זה כן רלוונטי למקרה שלו.
הנה תמונה שלקחתי עכשיו במערכת שלי ואין לי שום רכיב שמחובר ב-IDE
http://img191.imageshack.us/img191/2627/shot19122009204123.png
