8RDA3+1.1 - + 2500xp
I recently bought those two items and installed them, now i have this slight problem that i can't really understand nor fix, i would appriciate any help given.
My Aquamark3 score ar as followed:
CPU: AMD Athlon XP 2500+ CR: 1837 MHz SRAM: 512 MB OS: Microsoft Windows XP
GFX: NVIDIA GeForce4 Ti 4400 (*StarStorm* 44.67q) CM: 304 / 635 MHz VRAM: 128 MB DRIVER: 6.14.10.4467
# 1 AquaMark Score: 22659 (CPU: 3379, GFX: 3408) FPS: 22.66 TPS: 7550 K Compare
RES: 1024x768 x 32bit AA: Off AF: 4x DETAILS: Very High View
My problems origin is at the CPU score , it is 3379 which is kinda weird considering all thee other compared systems with the SAME spects have 6200 and above.
i was wondering if anyone can help me solve this problem, maybe i didn't configure my cpu correctly at the bios or something.
Thank you.
Is the FSB set to 166MHz ?
YEs it is set to 166MHZ, ..
