a7n8x del problem!
After working all the kinks out of my hardware, updating the BIOS, updating the drivers the thing I can't fix is my sound problem. The front speakers don't work. The actual speakers do work because I put them in as the rear speakers to test them, but when I put my headphones into the line out jack (where the front speakers are supposed to go) I get no sound when I run the nForce's Test Tone. Anyone know of a simple solution to this problem and make me look like an idiot. It'll be worth it if I can get my speakers to work.
i got all the new drivers
bios 1006
all windows update
nvidia 2.45
and the front speaker line out(green one) dont preduce sound!
help me plz
email: peledavi@bezeqint.net
system :
amd 2200+
256 winbond ddr (400/3200)
a7n8x deluxe rev 1.04
winXP
I had a lot of problems with the sound also with that mobo...
Check out this FAQ:
http://www.nforcershq.com/forum/viewtopic.php?t=3199
It helped me out with some sound issues.
But when I moved to Win XP, all the sound problems were gone except for a couple static noises I hear some times..
