Panasonic Toughbook CF-F8 מול dell-latitude-e6400-p96 לשימושים עסקיים. מה עדיף?
תודה מראש.
מפרט הפנסוניק (במחיר של כ 7800ש"ח כולל מעמ, ויסטה ו3 שנות אחריות):
Mobile Computing Intel® Centrino® 2 with vPro™ technology
Platform – Intel® Core™ 2 Duo processor SP9400 (2.40GHz, 6MB L2 cache, 1066MHz FSB)
– Mobile Intel® GS45 Express Chipset
– Intel® Wireless WiFi link 5100 AGN Network Connection (supporting 802.11a/b/g, n draft 2.0 compliant)
OS Genuine Windows Vista® Business Service Pack 1 (including XP Downgrade License) or
Genuine Windows® XP Professional (Downgrade Service with Vista® License)
RAM 2GB (DDR2-533 SDRAM, max. 4GB)
Graphic Chip Intel® GS45 graphics controller, UMA (Win XP: max. 1024MB; Win Vista: max. 1551MB with additional 2GB memory)
HDD 250GB (SATA, shock resistant and easy accessible)
Optical Disc Drive DVD Multi Drive
LCD 14.1” anti-glare Active Matrix (TFT) colour LCD (flexibly mounted)
1280 x 800 pixel (WXGA), 16 million colours
LCD Cabinet Magnesium alloy (withstands pressure of up to 100kgf)
Bluetooth™ Version 2.0 + EDR; slide on/off switch
WLAN IEEE 802.11a/b/g, n draft 2.0 compliant (max. 54Mbps); slide on/off switch
LAN IEEE 802.3 10Base-T, IEEE 802.3u 100Base-TX, IEEE 802.3ab 1000Base-T
Modem Data: 56kbps (V.92), FAX: 14.4kbps
Sound 24bit stereo, conforms to Intel® High Definition Audio
Stereo speakers
Input Devices Touchpad and keyboard (both water resistant - 200ml)
Indicators 9 LEDs (Power, ECO, Battery, HDD, Caps Lock, Scroll Lock, Num Lock, SD card, Disc)
Interfaces External display (VGA port): Mini D-sub, 15-pin
Headphone: Mini-jack, 3.5 DIA, stereo
Microphone: Mini-jack, 3.5 DIA, stereo
DC In: Jack
USB 2.0: 3x 4-pin
Modem: RJ-11
LAN: RJ-45
Mini Port Replicator: 78-pin
Expansion Slots PC Card: 1x Type I or Type II (3.3V: 400mA, 5V: 400mA)
SD/SDHC Memory Card: 1x
RAM Module: 1x DDR2 200-pin SO-DIMM (1.8V / PC2-5300 / DDR2 SDRAM)
Power Power Consumption: Approx. 35W/max. 80W (maximum when recharging)
AC Adaptor Input: 100-240V AC, 50Hz/60Hz; Output: 16V DC, 5.0A
Battery: Li-ion (10.8V, 5.8Ah)
Battery life: Approx. 6h (Mobile Mark™ 2007, 60cd/m², Vista® Model, Economy Mode (ECO) disabled)
Charging time: Power off: approx. 5h; power on: approx. 6.5h
Dimensions (WxHxD) 326mm x 25.5/48.5mm* x 251mm / 12.8” x 1.0/1.9”* x 9.9” (excluding protrusions; *front/back)
Weight 1660g / 3.66lb (standard model including battery)
מפרט dell:
http://www.notebookclub.co.il/prod-dell-latitude-e6400-p96.htm
ה-Panasonic הוא דגם מאוד מעניין. אין מחשבים אחרים בגודל הזה ובמשקל הזה.
עם זאת, יש לו חסרונות לעומת ה-DELL. לטעמי, סידור הכפתורים במקלדת פחות נוח, וכן רזולוציית המסך נמוכה (הייתי מעדיף 1440X900 כמו ב-DELL).
כמו כן, יש לו טאצ'פאד עגול, שאולי צריך להתרגל אליו, ואין trackpoint, בניגוד ל-Latitude ורוב המחשבים העסקיים.
ביקורת על ה-CF-F8:
http://www.trustedreviews.com/laptops/review/2009/04/20/Panasonic-ToughBook-Executive-CF-F8/p1
מבין אלו אישית הייתי הולכת על ה-Panasonic מבלי לחשוב פעמיים (אם כי הרזולוציה היא באמת הדבר המרכזי שמפריע לי בו). זה נובע מסדרי העדיפויות האישיים שלי ששמים ניידות וחיי סוללה במקום גבוה מאד. לעומת זאת, מכיוון שהרזולוציה ממילא נמוכה הייתי נוטה לבחור במשהו כמו ה-E4300 של דל שנותן משקל נמוך (עדיין טיפה גבוה מזה של ה-CF-8) וחיי סוללה טובים עם אותה רזולוציה ב-13.3" אך ללא החסרונות האחרים ש-QTTP ציין. ההבדל בגודל הטקסט בין 14.1" ל- 13.3 ברזולוציה זהה אינו שיקול מהותי לדעתי.
הכל שאלה של מה חשוב לך הכי, משקל, רזולוציה או פונקציות אחרות.
תודה על התגובות המהירות! קבלו חח על הפורום המקצועי. ביליתי בו מספר שעות לא מבוטל היום.
